EAGLE User Support (English) New stencil layer
  • Replies 8 replies
  • Subscribers 189 subscribers
  • Views 1351 views
New stencil layer
Gustav_M
Gustav_M over 14 years ago
Hi
This is a suggestion that I am al already using and will continue to use
for the future.
For every component that I am using I have defined a stencil cut out for
each pad (only using SMD components).
The stencil cut out is defined in layer 53 (renamed to tStencil) and layer
54 (bStencil).
The advantage of this approach is two fold: (1) the reduction is done once
and for all and does not require manual work from on the stencil supplier.
(2) There are places where the stopmask is open, but the PCB does not
require solder paste. This is typically connectors, and through holes that
are only used for testing in development but not for production.
I wish to share this with Cadsoft, because I hope that the standard
libraries will be updated and upgraded with stencil layer.
Also note how Texas Instruments are beginning to include a 'recommended
stencil' with their recommend foot print.
PS: I have even defined a stencil frame cutout as a special component. This
matches exactly the stencil holding frame that is used in production.
Again, this removes a source of error and manual editing by the company
that produces the stencil.
  • Gustav_M
    I did catch your humor and I thought it was funny, but I also felt stupid
    that I suggested something which was already implemented better in Eagle.
    :blush: And therefore, I replied to divert the attention from that. image
    In the 90'ies I've used the vi editor on a HP unix system, but then went to
    emacs and now pnotepad.
    e14 Contributor over 14 years ago in reply to Gustav_M
    On 10/12/2011 01:47 PM, Gustav wrote:
    Good morning Chuck,
    Here in Denmark it is late night already.
    Maybe I should have posted my suggestion under support, but with all due
    respect the vim editor is written by Bram Moolenaar (born in 1961, in
    Lisse, province of Zuid-Holland, Netherlands). That is not "home grown,
    red-blooded, all American"...
    Good evening, Gustav,
    The excessive adjectives I used to describe a plain text editor was just
    a feeble attempt at humor, an expression referring to any plain text
    editor.  In an international forum such as this newsgroup, I should have
    known that many forms of humor will rarely cross cultural boundaries
    with any degree of success, but of course that didn't stop me from trying.
    I suppose I could have replaced "all American" with "all Terran" as I'm
    fairly certain that such editors do not include extraterrestrial
    influence... but then again maybe they do.
    For what it's worth, Bram Moolenaar has done an excellent job with vim.
    I have been using it's predecessors, vi and ex, since the late 70's.
    When vim came along in the early 90's, it provided many additional
    features that were welcome tools on my desk.  To this day, vim remains
    my text editor of choice.  I've even go so far as to install the jvi
    add-on to NetBeans providing me with vi-like editor commands.
    Enjoy,
        - Chuck
  • Gustav_M
    Gustav_M over 14 years ago in reply to e14 Contributor
    Good morning Chuck,
    On 10/12/2011 05:24 AM, Gustav wrote:
    No, I didn't know that.
    Are you suggesting, that the cream layer is used for stencil?
    I think, that if you make the stencil automatically from the stop mask or
    any other layer, then you will not get it right.
    If you have a link to the documentation of common practice of how to make
    the stencil, I am interested to see it.
    Good morning, Gustav,
    Using a good old fashioned, home grown, red-blooded, all American, plain
    text editor like vim, emacs, or even notepad, add these lines to the
    section near the top of your .cam file:
    Section=BotPaste
    Section=TopPaste
    ... and add the following two sections to the end of your .cam file:
    Name="Bottom Solder Paste"
    Prompt=""
    Device="GERBER_RS274X"
    Wheel=".whl"
    Rack=""
    Scale=1.000000
    Output="ParNumber-RevX-BottomPaste.gbr"
    Flags="0 0 0 1 0 1 1"
    Emulate="0 0 0"
    Offset="0.0mil 0.0mil"
    Sheet=1
    Tolerance="0.000000 0.000000 0.000000 0.000000 0.000000 0.000000"
    Pen="0.0mil 0.000000"
    Page="12000.0mil 8000.0mil"
    Layers=" 32"
    Colors=" 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 6 6 4 8 8 8 8 8 8 8 8 8 8 8 8 8
    4 4 1 1 1 1 3 3 1 2 6 8 8 5 8 8 8 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 4 2 4 3 6 6 1 1 1 1 1 1 1 1
    1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    1 1 1 1 1 1 0"
    Name="Top Solder Paste"
    Prompt=""
    Wheel=".whl"
    Rack=""
    Scale=1.000000
    Output="ParNumber-RevX-TopPaste.gbr"
    Emulate="0 0 0"
    Sheet=1
    Layers=" 31"
    1 1 1 1 1 1 0"
    Hope this helps.
    Enjoy,
        - Chuck
    Yes, that's exactly what that layer is for.
    And normally, all SMD pads automatically generate implicit information
    on that layer (if not disabled), based on the masks settings in the DRC.
    It's quite similar to the solder stop masks.
    Tilmann
    Tilmann
  • Gustav_M
    Is stencil the same as cream layers? You know you can set a flag on smd
    pads to not have cream on them and override the default cream size defined
    in DRC settings by drawing in cream layers manually?
