EAGLE User Support (English) Cam Job Creating gerber files with Out of Range warnings on Viewer
  • Views 1225 views
When I create the gerber files for a board it gives an error in the gerber viewer (ViewMate) that says "Coordinate exceeds largest allowed value (1000.0 inches). Coordinate maps to X=1190.8922 Y=-2147.483649 inch using current origin and Data Format: 2.4, Leading zeros suppressed, Absolute, English.
I have checked over the entire view of the board file to see if something was placed outside of the dimension frame but can find nothing. Any suggestions?
*I would attached the .brd file but it won't let me for some reason*
Eric
    Morten Leikvoll schrieb:
    >> If you WINDOW FIT; and the board fully fits in the editor window then I
    >> agree with Tilmann and it is likely the data format
    >> This has come up before. Search the previous posts. Recommend you do that at
    >> http://www.eaglecentral.ca/forums/
    Of course all the exported layers should be visible before doing win fit.
    It doesn't matter - FIT always considers all elements, visible or not.
    I have seen occations of wire ends moving far out by corruptio, but
    my suspicion lies at the import function and unit conversion. Many
    gerber importers arent very smart when it comes to autodetecting the
    number of decimals.
    Exactly that was my first guess - and especially ViewMate is known for
    some misinterpretations.
    Tilmann
    >> Thanks,
    >> Eric
    Of course all the exported layers should be visible before doing win fit. I
    have seen occations of wire ends moving far out by corruptio, but my
    suspicion lies at the import function and unit conversion. Many gerber
    importers arent very smart when it comes to autodetecting the number of
    decimals.
    Eric
    HTH
    Warren
    news.cadsoft.de
    Eric
    Hi Eric,
    We've run into this issue before, in that particular case one of the
    components was improperly made and that introduced some sort of
    corruption into the file.
    Removing the component in question and recreating it correctly resolved
    the problem.
    hth,
    Jorge Garcia
    Most probably, it's simply the wrong data format, or one more bug in
    ViewMate, or both. First I'd try a decent gerber viewer (several
    problems have been reported with ViewMate, but I never had problems with
    GCprevue) and also check the data format (if the device in the CAMP is
    set up the same way as your import to the viewer).
    There should be a size limit (meanwhile).
    However, I don't think it's related to the board, so that attachment
    wouldn't be of any use anyway. If at all, you could provide the gerber
    file in question (zipped, please).
    Tilmann
