EAGLE User Support (English) Modal Commandline and Shortcut keys
  • Views 585 views
If we could have scroll-lock or something to turn on/off the commandline, we could finally have quick shortcuts to most commands.
m - move
c - copy
r - rotate
d or del - delete
etc...
Right now shortcuts can only be by F-buttons and it's really hard to remember which does what.  Especially since you can assign em yourself and there simply isn't enough to go around.
Having em defineable, but on a single-letter shortcut would speed up editing and allow 2-handed work.  No more moving mouse back and forth between board/schematic and button-menu for different operations.
    "davem" <imix@bigpond.net.au> wrote in message
    news:j7ngnb$lf5$1@cheetah.cadsoft.de...
    >I agree with turning on or off the command line entry box, Its always in
    focus,
    We need a user definable parameter to toggle this on or off, and if off ,
    the SINGLE key stroke short cuts would be activated, ( if any have been
    defined)
    This is such a simple request!
    I hardly ever use the command line! I don't see the need, to old school (
    invented before the mouse! ) and I don't care what anyone thinks of that!
    Again this is one of those features that could be implemented VERY EASILY,
    and not effect anyones current use, I would suggest by default its ON,
    therefore, changed behaviour is not noticed, but allow this changed by the
    user, and save with the user preferences.
    I support this. There is really no conflict here. Eagle has moved towards
    supporting GUI and Im sure it will move even further. This is analogue to
    the vi vs notepad++ discussion and notepad++ wins without a doubt.
    Converting the command line to a toobar should work fine. The ones that
    wants it should have it open, and the others open it when needed. The good
    side effect of hiding it is the extra hotkeys you get when the command line
    toobar is hidden, but they have to go when the toobar is visible.
    Am 19.10.2011 23:50, schrieb davem:
    focus,
    You might need that, I DON'T. Who is WE? You are certainly not speaking
    in my name, remember that.
    defined)
    I am old school and maybe I am way out. So you tell me (us image ) to
    write programs with a mouse only.
    Dave M
    Joern Paschedag
    davem wrote on Wed, 19 October 2011 17:50
    You might want to try it.  It's a powerful way to use Eagle, and faster for
    many things than clickety-clicking your way thru menus.  If you haven't
    used the command line, you haven't really used Eagle.
    focus,
    defined)
    Dave M
    Am 19.10.2011 13:41, schrieb kreature:
    m - move
    c - copy
    r - rotate
    d or del - delete
    etc...
    No. You can use all other keys, too. The keys in our institute are
    defined as, e.g.,
      Ctrl+M = move
      Ctrl+S = save ('write')
      Ctrl+D = delete
      Ctrl+A = add
      Ctrl+N = net
      etc...
    All pretty straightforward and easy to remember.
    Andreas Weidner
