EAGLE User Support (English) Autoroute misses simple routing
  • Views 227 views
Occasionally autoroute will miss really obvious tracking, I've just tried
autoroute on a new board, it's happily routed about 95%, and the remaining
5% are right next to each other with no obstructions between. Why won't
autorouter lay a simple straight track between the two. It's quite happy
for me to manually route between the two, but won't do it automaticaly.
Have I missed something? or is this just a quirk of the system?
    Maybe the routing grid is set to a large value?    Maybe your manual
    routing has violated some clearance limits which will get flagged when
    you run the DRC.
    Jim
