EAGLE User Support (English) quick question from a customer who received the files in Eagle format
  • Replies 15 replies
  • Subscribers 191 subscribers
  • Views 1094 views
esilviu
esilviu over 14 years ago
How do I check if holes for components are with the right drill?
He has no lbr file, nor will have.
so?
  • lix
    lix over 14 years ago in reply to esilviu
    Silviu E. schrieb:
    No, it implies changing grid and using a MARK command (that if it were by be
    could be named "FRTSRZRT" as well, because it's name doesn't make me think
    of relative coordinates). And there is no visual feedback for mark command
    (except the second pair of coordinates, placed hard to see next to the old
    ones).
    More, even this method is an approximation because A) it will be a multiple
    of grid points, and B) it relays on user placing the MARK cross as close as
    possible to the margin of the pad (of worse, at the left area of a circle
    for the drill size- you try this and will talk about later !)
    So, anybody? a quick and precise solution?
    This method is precise enough, if used properly (I use it with great success). For increased precision, you need to keep the ALT key pressed when placing the reference MARK. Keep ALT key pressed also when you measure distances, so you can move the cursor with increased precision (x 2 with the default grid settings). If this still is not enough, then modify the "grid alt" to 1/10 of the normal grid and you're done (btw, this is how I set my grid).
    Lix
  • jeromeabcpcb
    jeromeabcpcb over 14 years ago in reply to esilviu
    "eSilviu"  a écrit dans le message de groupe de discussion :
    jae0mj$g4n$1@cheetah.cadsoft.de...
    Sorry, Jerome if i am not polite. Those questions were addresed to Cadsoft,
    and I still wait for a short answer to transmit to my customer. It should be
    short and straight-forward, since customer's questions were ones of the
    simpliest possible.
    Klaus is right, this message does not belong to the suggest section. There
    is a userchat for such complaints.
    Eagle is not perfect. And I do not know any perfect software, even
    notepad.exe has flaws, despite being so simple.
    Your question was not clear so I suggested a couple of ways to make your
    measurement. Each seems like a workwaround, but I use them daily and they
    save me a lot of time, because I do not always want to get the same
    information, sometimes seeing that > 8 mils is sufficient, sometimes I want
    to measure exactly.
    Eagle approach is to be open to user customization. My colleagues use other
    CAD software and they keep complaining that this or that function does not
    behave the way they want, and they cannot change it, it's a closed system...
    Take opportunity of this open approach. If your customers require something
    special (here to measure the pitch or clearance) write them a  ULP to do
    exactly what they want, and to present the results with the best way <==
    that's very important too.
    If you cannot write it, ask someone to do it for you, there is no shame for
    that.
    Here is an exemple for the list of drills. Select the part, then run the
    ULP. That's the same approach as in Word, select the text, then click on
    bold. Your customer should manage to do it.
    You can do further processing of the data if necessary (display pad name,
    relative coordinates...). This is very powerful. The equivalent in other CAD
    software I know is to click on a pad, scroll a list until you get the drill
    size in mils, then click somewhere else to get the coordinate, and you are
    lost anyway as this is so unfriendly and unefficient.
    string list = "List of absolute coordinates and diameters of package drills
    (X,Y,diam in mm)";
    board(B) {
        B.elements(E) {
            if( ingroup(E) ) {
                E.package.contacts(C) {
                    if( C.pad ) {
                        sprintf( list , "%s\n%.2f , %.2f , %.2f" , list ,
    u2mm(C.pad.x) , u2mm(C.pad.y) , u2mm(C.pad.drill));
                E.package.holes(H) {
                    sprintf( list , "%s\n%.2f , %.2f , %.2f" , list , u2mm(H.x)
    , u2mm(H.y) , u2mm(H.drill));
    dlgDialog("Drills")
        dlgTextEdit( list );
    A last remark, a short question does not always imply a short answer. Here
    my best answer to your customer would be to provide customized tools (called
    ULP here, plugins, addons or toolboxes for others) to help the customer
    visualize exactly what he wants to see.
    Best regards,
    Jerome
    e14 Contributor over 14 years ago in reply to esilviu
    Cadsoft, and I still wait for a short answer to transmit to my
    customer. It should be short and straight-forward, since customer's
    questions were ones of the simpliest possible.
    When a forum member replies, be it good or bad, don't then bite their head
    off. Appreciate the time they have taken to aquire the knowledge and the
    time they  take to respond.
    If you think CadSoft should have made it easier  for you , explain why and
    how. make a specific detailed suggestion with a possible solution. Never
    expect it to be implemented, be grateful if it is.
    The problem with a quick question is:
    1) You will likely get a quick answer (short answer)
    2) There is no short answer
    We have seen this quick question before.
    A PCB designer designed in Eagle. The customer was advised they could
    download the free version of eagle to view the progress. With no experience
    they expected to use it as a 'dummies' viewer, couldn't so asked the
    designer how to do a number of things The designer didn't know those answers
    and was frustrated there was not a way to easily instruct the client how to
    drive Eagle, over the phone.
    If suspect this is your scenareo. A client familiar with Eagle  would not
    ask this question.
    Another possible solution pad spacing  question  is to generate gerbers and
    use a gerber viewer to get the measurments as the gerbers are checked , if
    the client has a gerber viewer and familiaer with using it.
    If the client is not skilled in either of the above mentioned software  it
    is encumbant upon you, and good for business, to provide the answers.
    See how long these replies have had to be to your short question?  Next time
    please paint the full picture so you can get a quick quality answer.
    All the best
    Warren
    news.cadsoft.de
  • esilviu
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:jaeb13$ugt$1@cheetah.cadsoft.de...
    If you want to measure the distance between two points in EAGLE, the
    MARK command is what you should use, as Jorge has suggested.
    The MARK command has it's flaws, and for holes of the components is almost
    unusable.
    And yes, I know what "suggest/betatest/userchat" forums are for.
    What I'm trying to do is to "suggest" to Cadsoft that a elementary tool neds
    to be added.
  • esilviu
    "Jorge Garcia" <jorge@cadsoftusa.com> wrote in message
    news:jae9j7$p6t$1@cheetah.cadsoft.de...
    On 11/21/2011 2:38 PM, eSilviu wrote:
    >> "Jorge Garcia"<jorge@cadsoftusa.com>  wrote in message
    >> news:jae950$krg$3@cheetah.cadsoft.de...
    >>> On 11/21/2011 9:15 AM, eSilviu wrote:
    >>>> Question 2:
    >>>> How do I measure clearance betweem two IC pads?
    >>>> There is a quick answer? Why?
    >>> Hi eSilviu,
    >>> See Jerome's response, or use the dimension tool in V6 once it's
    >>> released.
    >>> Best Regards,
    >>> Jorge
    >> Those two are REAL QUESTIONS, that needs answer in max 24h... not half
    >> year.
    >> I can't answer my customer with "RTFM" or "Wait 1 year, maybe Cadsoft
    >> will
    >> implement a ruller "
    Hello eSilviu,
    You could also set the grid to a small increment (1mil or whatever is
    convenient), use the mark command to place a relative origin at one end of
    what you want to measure and then take your mouse cursor to the other
    point, you can then read off the distance directly by looking at the
    relative mouse coordinates.
    This is a reasonable solution that doesn't involve counting squares, or
    some sort of wacky workaround.
    Best Regards,
    Jorge
    ones).
  • esilviu
    esilviu over 14 years ago in reply to esilviu
    >>>> Question 2:
    >>> Hi eSilviu,
    >>> released.
    >>> Best Regards,
    >>> Jorge
    >> year.
    >> will
    Hello eSilviu,
    Best Regards,
    Jorge
    ones).
  • esilviu
    news:jae93m$krg$2@cheetah.cadsoft.de...
    >> so?
    Hi eSilviu,
    He can extract the libraries using exp-project-lbr.ulp and measure them
    there.
    If that customer can open Eagle or double-click on xx.brd doesn't mean it
    must know C,Java,Ulp or anything else.
    Some elementary tools must be there in the GUI of Eagle, but they aren't.
  • esilviu
    >> so?
    Hi eSilviu,
    there.
  • esilviu
    >> Question 2:
    Hi eSilviu,
    See Jerome's response, or use the dimension tool in V6 once it's released.
    Best Regards,
    Jorge
    Those two are REAL QUESTIONS, that needs answer in max 24h... not half year.
    I can't answer my customer with "RTFM" or "Wait 1 year, maybe Cadsoft will
    Question 2:
    Hi eSilviu,
    Best Regards,
    Jorge
