EAGLE User Support (English) quick question from a customer who received the files in Eagle format
  • Replies 15 replies
  • Subscribers 191 subscribers
  • Views 1106 views
esilviu
esilviu over 14 years ago
How do I check if holes for components are with the right drill?
He has no lbr file, nor will have.
so?
    so?
    Hi eSilviu,
    He can extract the libraries using exp-project-lbr.ulp and measure them
    there.
    In V6 there will be a dimension tool and that can be used to double check.
    Best Regards,
    Jorge
    e14 Contributor over 14 years ago in reply to jeromeabcpcb
    Sure. Eagle expects every user to be a computer scientist.
    "Jerome" <jlamy@abc-pcb.com> wrote in message
    news:jaduao$vch$1@cheetah.cadsoft.de...
    Q1 : How do I check if holes for components are with the right drill?
    use drill legend and check the drill size for the pads you are interested.
    Or write a small ULP that lists the drill size for the selected components
    Q2 :  How do I measure clearance between two IC pads?
    Set the grid to 1 mil, and displayed with lines or dots, and check/count
    the spacing
    or, draw a line between the objects you want to measure, then with info
    you can get the length
    or, to check if you have at least (exemple) 8 mils clearance, draw a 8x8
    rectangle and move it around with your mouse
    or, check stats_brd.ulp to see the smallest clearance
    Jerome
  • esilviu
    esilviu over 14 years ago in reply to jeromeabcpcb
    sorry, I'm a noob. Where do I see that "drill legend"?
    ULP? me to write one? That's C/Java !! I only know how to dray electronics
    circuits...
    the spacing
    That's a workaround ! should I count dots on the screen?! in year
    2011?!!!!!!!!!!
    That's a workaround too! line has round terminations what to do with that?!
    Hey! That's a workaround too!
    I want to know exactly the distance between those two pads. It's so hard? so
    complicated?
    how do I know about this stats_brd.ulp ? it writes in the manual?! should I
    run every ulp one by one until I found one to do what I want?
    Sorry, Jerome if i am not polite. Those questions were addresed to Cadsoft,
    and I still wait for a short answer to transmit to my customer. It should be
    short and straight-forward, since customer's questions were ones of the
    simpliest possible.
  • jeromeabcpcb
    jeromeabcpcb over 14 years ago in reply to esilviu
    Set the grid to 1 mil, and displayed with lines or dots, and check/count the
    spacing
    or, draw a line between the objects you want to measure, then with info you
    can get the length
    Jerome
  • esilviu
    Question 2:
    How do I measure clearance betweem two IC pads?
    There is a quick answer? Why?
