EAGLE User Support (English) Processor power
  • Views 522 views
Processor power
I'm doing a fairly complicated 4 layer board.  I manually routed all the
power/ground/critical tracks.  The remainder I auto route on a 1mil grid
because of fine pitch parts.  It takes about 12 hours to complete.
I'm looking for recommendations on processor/memory combinations that
people have had good luck with to improve performance.  Also, does
anyone know if Eagle has or will have a 64 bit version?  I looked on the
cadsoft website but didn't find any info on that.  My current setup is
Windows XP Professional 32bit, AMD Athlon X@ Dual 3.10HHz, 4G RAM
    people have had good luck with to improve performance. Also, does anyone
    know if Eagle has or will have a 64 bit version? I looked on the cadsoft
    website but didn't find any info on that. My current setup is Windows XP
    Thanks for the suggestions
    Am 23.11.2011 17:56, schrieb John Friede:
    I had some machines with windows-xp and 4GB RAM. It turned out that win
    can not manage well the adresses above 3GB where some BIOS, graphic, I/O
    etc. is located. Reducing RAM to 3GB turned the PC's into well running
    machines. Give it a try, cost nothing image
    Joern Paschedag
    the power/ground/critical tracks.  The remainder I auto route on a
    1mil grid because of fine pitch parts.  It takes about 12 hours to
    complete.
    the cadsoft website but didn't find any info on that.  My current
    setup is Windows XP Professional 32bit, AMD Athlon X@ Dual 3.10HHz,
    4G RAM
    Your issue / question comes up regularly and always pertains to autorouting.
    Search the older posts for a number of conditions that cause long route
    times.
    BGA's, component spacing, inconsiderate manual routing and the big hitter,
    the routing grid.
    If you can double the grid to 2mil the time should divide by 4 to 3 hours
    and possibly less.
    See some of the times mentioned in earlier posts.
    I hope this points you in the right direction
    Warren
    news.cadsoft.de
    What I have gathered from the newsgroups and i could be wrong.
    Eagle can only use 1 core for routing as you can't do parallel process
    of that process. A second core would support the OS.
    I don't think the display update process is done on a different core
    either. The redraw while running is not too much overhead unless you
    have a video card without a GPU
    On the hardware.
    CPU with large L3 and L2 cache and high clock (HT) and buss speed. 4
    cores and slower clock will be slower 2 cores and faster clock.
    I am guessing you are running DDR2 at 533Mh or 800Mhz. With DDR3 it
    looks like you can get to 1800Mhz. With that I would think you would get
    2 to 4 time faster depending on how much you pay to get the fastest CPU
    and Memory available.
    I don't know if anybody had benchmarked XP vs Linux on autorouting time.
    HTH
    Paul R.
