EAGLE User Support (English) Strange thing like "connector" in a trace
  • Views 436 views
Please see the attached image.  I don't know what that strange thing
(red rectangular-oval thing with lines crossed in it) in the trace.
Even after I rig-up the trace, that thing is still there.  I want to
remove it, but I can't.  It is causing an error when I do DRC check.
Please advise.
    On 12/3/2011 4:58 PM, Warren Brayshaw wrote:
    AL wrote:
    >> Hi,
    >> Please advise.
    The DRC check has placed it there (red rectangular-oval thing with lines
    crossed in it) to show you where an error is. In the DRC dialog you will see
    why the DRC thinks it's an error.  It is being generated each time you run
    DRC and will remain there on your design until you fix the error, perform a
    'Clear errors'  or 'approve' the error.
    Looking at the image I suspect there are two errors there. I'd 'Ripup'
    everything , above, below and within the white box. Then perform a
    'Ratsnest'. Then route the traces again.
    If you grab the end of the upper trace and 'move' it out. Do the same with
    the lower trace. If the two error traces are attached you will see them
    stretch out with the other traces. With that view you should be able to
    correct the placement errors.
    Warren
    Thanks all for the answer.  So, I didn't have to rig-up everything.
    Here are the steps:
    1. Clear all the errors
    2. Rig-up that particular trace
    3. Then re-route that trace
    Thanks, all!
    AL wrote:
    Please advise.
    Warren
    news.cadsoft.de
    I agree. It looks like the DRC (Design Rule Check) is advising you of a
    rule violation. Have you tried ripping up the trace and rerouting it?
    On 12/3/2011 6:16 PM, AL wrote:
    Please see the attached image. I don't know what that strange thing (red
    rectangular-oval thing with lines crossed in it) in the trace. Even
    after I rig-up the trace, that thing is still there. I want to remove
    Please advise.
    Does the DRC check error give you any clues about the problem?   It
    looks like you have an abrupt change in trace width in the middle of a
    run.   Perhaps the little segment is below the minimum width for the
    design rules?
    Jim
