EAGLE User Support (English) Hyperlinks
  • Views 1134 views
Hyperlinks
On 12/02/2011 12:06 PM, Ben wrote:
> what's about a hyperlink in 'Attributes'?
> Could be usefull for providing a link to the datasheet of a device on
> the homepage of the manufacturer.
> The hyperlink should appear if you open the 'Info' window of a device
> (like attributes do already).
we do have hyperlinks in all kinds of Eagle descriptions (like for
packages, devices, since V6 also sheets, board and more).
The best way to do what you want is the device description.
So I don't think this is necessary.
Please post further mails on this in our suggest forum !
Walter Spermann
    @Christian:
    thank you for sending this ULP, but:
    I know that there are several ways to realize hyperlinks in schematic,
    like your ULP or an "attribute" in a "device" (I'm using this approach
    already).
    I was just looking for a more user-friendly solution like a hyperlink in
    the "info"-box of a device in a sheet or board.
    It's a little bit strange that hyperlinks work in "all kinds of Eagle
    descriptions..." (like Cadsoft says) but not in a "Info"-box, although
    this box shows absolutely the same attribute defined in a device!
    Am 06.12.2011 21:39, schrieb Jorge Garcia:
    On 12/6/2011 4:28 AM, Christian Bohrer wrote:
    >> "Ben"<frank.dannull@meinberg.de> a écrit dans le message de news:
    >> jbkg73$18g$1@cheetah.cadsoft.de...
    >>> I'm using the device description right now.
    >>> I just think that it's not a logical approach that I have to use the
    >>> "ADD" command to get the datasheet link for a device that is already
    >>> placed in my schematic...
    >> I have attached an ULP for you: HyperLink.ulp
    >> You just have to add an attribute named "HYPERLINK" in your
    >> device/variant,
    >> fill it with the url of your choice and add the device in your
    >> schematic sheet.
    >> Then, in the schematic sheet, select this device with a group and run
    >> HyperLink.ulp
    >> You can also do the same in the board.
    Hi Christian,
    You may want to consider uploading your HyperLink.ulp to the website so
    that other may benefit from it as well. Since we are running the
    Smartest EAGLE contest you might as well, through it in there as well.
    Obviously you would only be interested in the contest if you didn't own
    a normal pro license.
    In any case the community will benefit, for your ULP.
    Thanks for the work you've put into it.
    Best Regards,
    Jorge Garcia
    Cadsoft Computer
    You just have to add an attribute named "HYPERLINK" in your device/variant,
    fill it with the url of your choice and add the device in your schematic sheet.
    Then, in the schematic sheet, select this device with a group and run HyperLink.ulp
    Hi Christian,
    Best Regards,
    Jorge Garcia
    Cadsoft Computer
    "Ben" <frank.dannull@meinberg.de> a écrit dans le message de news:
    begin 666 HyperLink.ulp
    M#0IS=')I;F<@55),(#T@(DA94$523$E.2R([#0H-"FEF("AB;V%R9"D@8F]A
    M<F0H0BD@>PT($(N96QE;65N=',H12D@>PT("!I9B H:6YG<F]U<"A%*2 F
    M)B!%+F%T=')I8G5T95M54DQ=("$]("(B*2![#0H@(" @<W1R:6YG(&AT=' @
    M/2!%F%T=')I8G5T95M54DQ=.PT*(" @('-Y<W1E;2@B8VUDF5X92 O8R!S
    M=&%R=" B("L@:'1T<" I.PT("!]#0H@?2 -"GT-"@T:68@*'-C:&5M871I
    M8RD@<V-H96UA=&EC%-#2"D@>PT(%-#2"YP87)T<RA0*2![#0H@(&EF("AI
    M;F=R;W5P*% I("8F(% N871T<FEB=71E6U523%T@(3T@(B(I('L-"B @("!S
    M=')I;F<@:'1T<" ](% N871T<FEB=71E6U523%T[#0H@(" @<WES=&5M*")C
    K;60N97AE("]C('-T87)T("(@R!H='1P3L-"B @?0T*('T@#0I]#0H-"@``
    end
    Am 06.12.2011 08:16, schrieb Ben:
    Walter Spermann
