EAGLE User Support (English) Is there a snap to grid feature in the   layout editor?
  • Views 11416 views
a few days a go, I had to copy and paste a layout+schematic, that all
worked out fine, but the parts don't align to my grid, ( at least the part
origins don't.)
This made it tedious for manual routing,
I had to put my parts "back on grid", so to speak, but it would be nice if
there was a "Right-Click" option called, "Snap to grid" for parts, which
will align parts to the nearest grid lines.
what do you think?
Dave M
    davem wrote:
    I knew that one,
    We need a snapping command key for snapping a wire's vertices back on
    grid, is there such a thing?
    Again its  the same action  Hold the CTL key as you select the end of the
    wire with the MOVE command. The end of the wire will snap to the current
    grid
    I wish that wires could only be drawn at 90 or 45 degs, when moving
    vertices around, I spend most of my time realign traces.
    I'd like that to..
    I like the MS Paint method of holding the shift as you create a line to
    constrain it to orthagonal or 45 degrees
    Warren
    news.cadsoft.de
    I knew that one,
    We need a snapping command key for snapping a wire's vertices back on grid,
    dave M
    davem wrote:
    HI Guys,
    Damn!!!!! you you guys are right!
    I should of read the f!@#$% manual!!!!
    I wasted so much time retyping coordinates to align these off grid
    parts, I just tried the COMMAND + MOVE and works on the mac
    perfectly, this will save tonnes of time.
    The should be a help hint in the bottom status bar that show the
    options.
    Also handy is using that same combination with the WIRE command. In this
    case the new wire is snapped to the end of the last (closest wire)
    This snapping functionality is a little hard to find in the manual  as there
    is no dedicated section devoted to snapping to grid.
    Warren.
    news.cadsoft.de
    e14 Contributor over 14 years ago in reply to WestfW
    HI Guys,
    I wasted so much time retyping coordinates to align these off grid parts, I
    just tried the COMMAND + MOVE and works on the mac perfectly, this will
    The should be a help hint in the bottom status bar that show the options.
    Thanks!!!
  • WestfW
    WestfW over 14 years ago
    There's a CTRL-click that does this during the "pick up" part of the
    Move command.  Or maybe option-click or cmd-click, depending on OS or
    Keyboard.  (definitely cmd-click for Mac.)
    BillW
    davem wrote:
    part origins don't.)
    nice if there was a "Right-Click" option called, "Snap to grid" for
    parts, which will align parts to the nearest grid lines.
    Hold down the CTL key as you select the part and its origin will snap to the
    displayed grid
    Warren
    news.cadsoft.de
