It would be very useful if you could set the MARK from within a information
dialog using the coordinate information of the object.
The attached shows an example for the wire object.
The mark should be set upon exiting the dialog or clicking 'apply' giving a
visual indication that the correct end of the wire had been selected.
I see this being useful for the wire and arc ends, and circle center.
Currently setting a MARK off the current grid requires you to specify the
coordinates which are usually obtained from object information dialogs.
Unfortunetly this takes multiple copy and pastes or hopefully you remember
the figures correctly to type. Generally the current process is painful.
Thank you for the consideration
Warren
Cur
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
