EAGLE User Support (English) HEEEEEEELP PANIC Cant open board from project
  • Replies 11 replies
  • Subscribers 189 subscribers
  • Views 1194 views
This week I upgraded from version 5.11 to 6.00 .
Yesterday I saved a project , schematic and board, but now after opening the
schematic again I get a error.
In a different window it says:
Loading
C:/Users/h.arends/Documents/Eagle/projects/Turntable/Arduino_Nano_V020.brd
Error:
line 1308, column 286: Unexpected ''.
If this means that I have to redo that complete board again No Thanks
version 6
Any suggestions how to solve this problem
    On 14.02.2012 13:15, Wolfgang Sachs wrote:
    Hello Richard,
    I've got a similar problem, when trying to open an existing schematic from 5.11 version. An error message appears, see below, and no sch will be opened. Strange kind of message, in the whole project there isn't any package DKONT5 5F.
    Wee need a working fix at this stage, because we want to transfer our projects to the new version of course. Or would you recommend to use the 5.11 until the 6.1 is stable ?
    Kind regards
    W. Sachs
    EAGLE Update-Bericht
    Datum: 14.02.2012 13:09:29
    Datei: C:/Dokumente und Einstellungen/sachsw/Eigene Dateien/EigeneDocs/Projekte/Layout/LayoutV1_1/test5.sch
    Beim Einlesen der intermediären XML-Datei ist ein Fehler aufgetreten.Die XML-Datei wurde als
    C:/Dokumente und Einstellungen/sachsw/Eigene Dateien/EigeneDocs/Layout/LayoutV1_1/test5.rpt.sch
    in ein Text-Editor-Fenster geladen. Warnung(en):
    Zeile 1531: Ungültiger Wert 'DKONT 5F' für Attribut 'name' im Tag<package>
    Fehler:
    Zeile 1545, Spalte 10: Ungültiges/fehlendes Attribut 'name' im Tag<package>
    Please send me the file in question by email, so that I can look into
    it.
    Richard Hammerl
    e14 Contributor over 14 years ago in reply to TonKonings
    Hello Richard,
    Kind regards
    W. Sachs
    Zeile 1531: Ungültiger Wert 'DKONT 5F' für Attribut 'name' im Tag <package>
    Fehler:
    Zeile 1545, Spalte 10: Ungültiges/fehlendes Attribut 'name' im Tag <package>
  • TonKonings
    TonKonings over 14 years ago in reply to e14 Contributor
    Hi Harry/Richard
    Any news on this issue?
    I have the same problem at this moment.
    Only difference is that i made the board in eagle V6.1.0 for the start.
    This happend already 3 times. And getting tired to redraw the board almost every time i made some changes.
    Kind regards,
    Ton
    See your mail on hotline@cadsoft.de
    "Richard Hammerl"  schreef in bericht
    news:jcq95i$h22$2@cheetah.cadsoft.de...
    On 19.12.2011 23:12, Harry H. Arends wrote:
    I have seen the subject mentioned.
    But my problem is NOT the same.
    I did made alterations on the design and whilst saving I got the message.
    After that opening the schematic and board, the schematic opens correct
    but the board doesn’t open but shows a text message as stated.
    I went back to a backup and redone the whole design yesterday, one
    Sunday with the family gone.
    So as I have paid for an update to the new version I keep on working in
    version 5.11 unless I got a answer from Cadsoft.
    Harry
    "Richard Herman" schreef in bericht
    news:op.v6mz88n56i2wlp@homer.fritz.box...
    Op Sat, 17 Dec 2011 14:32:29 +0100 schreef Harry H. Arends
    <info@oldtimetech.nl>:
    >> Then I observe that on top of the board window suddenly a Black/Yellow
    >> ribbon appears saying F/B Annotation has been severed
    see: "V6 F/B Annotation has been Severed" from 3 days ago.
    It's just a warning. It will only turn into a problem if you change
    something in the window that has been left opened.
    Strange that the warning says "f/b annotation HAS BEEN severed". I should
    think that at least that must be: "Warning: f/b annotation could be
    severed if you close the schematic window"
    (not using V6 myself, yet)
    Richard
    Hi Richard,
    could you send me the file you can't load anymore and could you send
    also backup files, if any? So we can look into this...
    Richard Hammerl
    Harry
    Richard
    Hi Richard,
    Richard Hammerl
    After that opening the schematic and board, the schematic opens correct but
    I went back to a backup and redone the whole design yesterday, one Sunday
    Harry
    Richard
    Understood, thanks anyway.
    Element 14 User wrote on Sat, 17 December 2011 10:44
    Help . . . just got the same problem. I can't open a project, that I
    opened with the "demo" 6.0 version, anymore.
    You mean open it with Eagle 5 anymore?  If so, of course.  That is exactly
    what you would expect.
    Quote:
    The project is a pretty large one, with more than 1000 discrete
    components and I would like to continu with the version 5.11 very much.
    Please help.
    You don't need our help.  Go restore it from your backups.
    Help . . . just got the same problem. I can't open a project, that I opened with the "demo" 6.0 version, anymore.
    The project is a pretty large one, with more than 1000 discrete components and I would like to continu with the version 5.11 (pro) very much. Please help.
    Ron
    Richard
