EAGLE User Support (English) Eagle 6.0 crashes when deletibg a net ... sometimes
  • Replies 11 replies
  • Subscribers 189 subscribers
  • Views 2612 views
  • eagle
  • crash
  • bug
  • schematic
wayne2056
wayne2056 over 14 years ago
Here is a capture of an error I have received a number of times now.  It occurs occasionally when I delete a net.
After you click OK the program crashes and all work prior to last save is lost..
  • scottyhomer
    scottyhomer over 14 years ago
    I can confirm that version 6.1.0 does not have this problem for me on Linux.  Whatever changed between 6.0.0 and 6.1.0 seems to have fixed this issue, as I can no longer duplicate the original problem.
    Just confirmed that my test sequence doesn't fail in 6.1.0.
    I'm guessing this was the problem:
    - Fixed a crash if deleting a group containing a net wire and a junction in special constellation.
    On 1/5/2012 1:41 PM, Jason Tribbeck wrote:
    Okay - here's a short video on reproducing it:
    http://www.youtube.com/watch?v=sLp8WIgC-bY
    And an Eagle 6.0.0 file is available from http://www.tribbeck.com/misc/TakeObject.sch.zip
    Awesome Jason,
    Our developers really appreciate this, and I'm positive your fellow
    EAGLE brethren appreciate it even more.
    Best Regards,
    Jorge Garcia
    e14 Contributor over 14 years ago in reply to billpenner
    On 03.01.2012 21:58, billpenner wrote:
    The error is created when a junction is placed on a pin manually.  It will happen with either a wire or a net. Use net instead of wire. It works for me. Hope it will for you.
    Bill.
    I can't reproduce this. It's possible to place junctions manually on
    nets pin connections, not matter whether I use NET or WIRE.
    Using SuSE 12.1
    Richard Hammerl
  • billpenner
    billpenner over 14 years ago in reply to e14 Contributor
    Bill.
    Do you use NET or WIRE? With net the junctions are placed automatically. See
    the manual/online-help for details.
    r
    Guest wrote:
    Am 02.01.2012 15:34, schrieb Jason Tribbeck:
    Also happens on MacOS too, so probably happens on Windows as well.
    Although I've never seen the point of junction dots at those locations myself image Seems a bit ... superflouous...
    No crashes on my windows xp. Are those junctions placed by hand?
    Joern Paschedag
    Yes - you need to manually create them (which is why I've never seen it crash, as I never create joins manually).
    Joern Paschedag
    e14 Contributor over 14 years ago in reply to scottyhomer
    Also happens on MacOS too, so probably happens on Windows as well (just read the original posted message, so definitely so!)
