EAGLE User Support (English) Eurocircuits and V6 .brd files
  • Replies 26 replies
  • Subscribers 189 subscribers
  • Views 3277 views
Just mailed two designs to Eurocircuits this afternoon made by Eagle V6.
Received a reject as 'does not look to be a valid .brd file'.
I wonder if they know about the changes in V6?
Robert
    Robert wrote:
    On 22/12/2011 21:13, Uwe Bonnes wrote:
    >>> Eagle V6. Received a reject as 'does not look to be a valid .brd
    >>> file'.
    >> The new version is out only some two weeks. Give them some time.
    >> Board review for eurocircuit is in India to my knowledge, so perhaps
    >> even some more time is needed.
    >> Also think about delivering Gerber RS2xx. That way, data is fixed
    >> and not subject to subtile differences in setup.
    >> Bye
    Hmm, that will likely stop it solid. Altough Eurocircuits did build
    good boards based on .brd files for me in the past. Not having
    generated Gerber files at all, I will have some reading to do, as we
    want to build prototypes for customers in a few weeks. This is the
    moment where I regret to have upgraded to V6 early.
    In the online help, 'GERBER' does not do much, but I saw a gerber.cam
    file. Should the result be a collection of files, like a drill file
    etc?
    Cancelling and trying another board house right now might get me in
    the same problem again.
    Robert
    Review the tutorial that ships with Eagle, found in the DOCs folder.
    Section: Output of drawings and manufacturing data.
    Gerber is simple  and nothing to be affraid of. Note a drill file will need
    generating as well as the multiple files for the layers considerd Gerber.
    Before shipping gerbers, view them yourself. using a viewer. GC-Prevue and
    gerbv are a couple to try.
    It also helps if you understand the order of the process steps the
    manufacturer uses. That way you don't flipout when you view a Gerber copper
    layer with no holes depicted.
    Eurocircuits have a page
    http://www.eurocircuits.com/index.php/technology-guidelines/pcb-layout-data/117-cadsoft-eagle-brd-to-gerber-conversion-guidelines
    All the best
    Warren
    news.cadsoft.de
    >> Robert
    Well, that did not look that hard. Found the instructions, generated
    drill file and a 4-layer Gerber, zipped them up and updated my order.
    Hopefully that was the right way.
    Robert
    It is very important to verify that all the necessary files are there,
    contain the correct layers and are not mirrored.
    >> The new version is out only some two weeks. Give them some time. Board
    >> review
    >> for eurocircuit is in India to my knowledge, so perhaps even some more
    >> time
    >> is needed.
    >> Also think about delivering Gerber RS2xx. That way, data is fixed and not
    >> Bye
    Hmm, that will likely stop it solid. Altough Eurocircuits did build good
    boards based on .brd files for me in the past. Not having generated
    Gerber files at all, I will have some reading to do, as we want to build
    prototypes for customers in a few weeks. This is the moment where I
    file. Should the result be a collection of files, like a drill file etc?
    Cancelling and trying another board house right now might get me in the
    same problem again.
    Robert
    Robert
    The new version is out only some two weeks. Give them some time. Board review
    for eurocircuit is in India to my knowledge, so perhaps even some more time
    is needed.
    Bye
    same problem again.
    Robert
    is needed.
    Bye
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Robert wrote on Thu, 22 December 2011 14:35
    V6.  Received a reject as 'does not look to be a valid .brd file'.  I
    Quite likely they haven't upgraded their software to deal with that yet.
    However, you shouldn't be sending Eagle BRD files to board houses anyway.
    That leaves too many judgement calls for the board house to make.  Create
    the gerber files yourself, then the board house knows what to do, and you
    can take the files to any other board house too.  Most board houses don't
    want Eagle files, or charge extra for doing the conversion to gerbers for
    you.
