EAGLE User Support (English) Eurocircuits and V6 .brd files
  • Replies 26 replies
  • Subscribers 189 subscribers
  • Views 3221 views
Just mailed two designs to Eurocircuits this afternoon made by Eagle V6.
Received a reject as 'does not look to be a valid .brd file'.
I wonder if they know about the changes in V6?
Robert
    On 15.01.2012 16:48, Richard Herman wrote:
    BTW: I got a free license for GerberLogix, which you suggested a few
    posts back, to see how it works/looks/feels. It is indeed a lot easier
    than GC Prevue, but I don't know how accepted it's output is with
    boardhouses (if that's important to you). My current PCB manufacturer
    accepts GC Prevue .GWK files for manufacturing and/or checking boards
    (they also accept Eagle .BRD files, but I've never used that).
    Richard
    Hello Richard, maybe because I am new to this, I find the whole process
    very 'unautomated'.
    Assuming that individual Gerber files are the standard, I am looking to
    create an ULP that counts all used layers and generates a board specific
    CAM file (board_name.cam). Which will put all Gerber files in a
    subdirectory and generates another subdirectory with all layer images.
    I did not find anything existing of this nature.
    Robert
    autodeskguest over 14 years ago in reply to e14 Contributor
    Richard
    very 'unautomated'.
    Robert
    Op Sun, 15 Jan 2012 16:17:18 +0100 schreef Robert Boers <robert@nospam.ch>:
    Thank you Richard. But I don't think it is obvious, as my question was
    concerning supply layers. In Eagle V6 supply layers are converted to
    signal layers, unlike in Eagle V5. So in V6 there is no special
    treatment needed and it becomes a .Lox layer. In Eagle V5 a supply layer
    is represented inverted and requires inversion. Correct?
    Robert
    Hello Robert,
    Correct. in V6 supply layers do not exist anymore. If your design started
    as a V5 design which was converted to V6, the supply layer is now a normal
    inner layer with a signal polygon on it.
    A snippet from the V6 changelog:
    • Supply layers:
       - Supply layers (i.e. layers with names that start with a '$') are no
    longer
         treated special. Layers for supply signals now need to be realized
    using
         signal polygons.
    Since they are not treated special (not inverted), it still looks obvious
    to me: Use the settings for an inner layer. Am I missing something?
    If the design was converted from V5 to V6, make sure to check the layer
    for correct connection.
    BTW: I got a free license for GerberLogix, which you suggested a few posts
    back, to see how it works/looks/feels. It is indeed a lot easier than GC
    Prevue, but I don't know how accepted it's output is with boardhouses (if
    that's important to you). My current PCB manufacturer accepts GC Prevue
    .GWK files for manufacturing and/or checking boards (they also accept
    Richard
    On 15.01.2012 14:46, Richard Herman wrote:
    Op Sun, 15 Jan 2012 10:41:45 +0100 schreef Robert <Robert@nospam.ch>:
    >> To answer part of my own questions, I found that I can setup a cam job
    >> for each layer that I need.
    >> The only question left is for generating a Gerber of an internal power
    >> plane. Do I include there also the pads (17), via(18) and
    >> dimension(20) layer?
    >> Robert
    >>> Morton, after some testing I found where the problem is. The
    >>> gerb274x-4layer.cam only looks at top, bottom, layer 2 and 15. I have
    >>> not found out how I can get it to look at my layer 3.
    >>> Furthermore, it will only deal with layer 2 and 15 as signal layers, and
    >>> I have my layer 2 defined as ground plane. Since I got my design error
    >>> free after some manual work, I'd like to keep it. Is there a way in
    >>> Eagle to move the layers to match gerb274x-4layer.cam or another way to
    >>> create Gerber files from my current design?
    >>> Regards, Robert
    Hello Robert,
    Because there isn't an always correct answer for this, visiting the
    Eurocircuits link Warren mentioned a few post earlier, gives me this:
    Layer conversion rules - syntax:
    Layer function (.file extension) consists of Eagle layer(s) : Eagle
    layer number & function + …
    Solder stop Component side (.STC) = 20 Dimension layer + 29 tStop laye
    Silkscreen Component side (.PLC) = 20 Dimension layer + 21 tPlace layer
    + 25 tNames layer
    Componentside (.CMP) = 1 Top layer + 17 Pads layer + 18 Vias layer + 20
    Dimension layer
    Inner layers (.Lox) = x Inner layer + 17 Pads layer + 18 Vias layer + 20
    Dimension layer
    Solderside (.SOL) = 16 Bot layer + 17 Pads layer + 18 Vias layer + 20
    Dimension layer
    Solder stop Solder side (.STS) = 30 bStop layer + 20 Dimension layer
    Silkscreen Solder side (.PLS) = 22 bPlace layer + 26 bNames layer + 20
    Dimension layer
    Milling (.MILING) = 46 Milling layer + 47 Measures layer + 20 Dimension
    Layer
    Excellon drill (.DRD) = 44 Drills layer + 45 Holes laye
    Cream frame Componentside(.PMC) = 31 tCream layer + 20 Dimension layer
    Cream frame Solderside (.PMS) = 32 bCream layer + 20 Dimension layer
    So the answer seems pretty obvious....
    Richard
    Robert
    plane. Do I include there also the pads (17), via(18) and dimension(20)
    layer?
    Robert
    >> Regards, Robert
    Hello Robert,
    Layer function (.file extension)     consists of Eagle layer(s) : Eagle layer
    Silkscreen Component side (.PLC)      = 20 Dimension layer + 21 tPlace layer +
    25 tNames layer
    20 Dimension layer
    Dimension layer
    Dimension layer
    Dimension Layer
    Richard
    layer?
    Robert
    Regards, Robert
    On 14/01/2012 22:24, Morten Leikvoll wrote:
    Robert<Robert@nospam.ch>  wrote:
    >> On 14/01/2012 17:44, Olin Lathrop wrote:
    >>> Robert wrote on Sat, 14 January 2012 11:33
    >>>> I see that layer 3 (in Eagle), which became .L15 in the Gerber files,
    >>>> was completely wrong, no wiring. This is probably because the quad
    >>>> layer
    >>>> board was defined in Eagle as (123*16).
    >>> That sounds like you used layers 1, 2, 3 and 16, but wrote out layers 1, 2,
    >>> 15, and 16.  I always use consecutive layers from one except that the
    >>> bottom layer is 16 to avoid any confusion.  Still, that should have been
    >>> easily spotted when previewing the gerber files, so I still don't see how
    >>> that could have happened.
    >> Well, I simply ran the gerb274x-4layer.cam job. It generates tabs for the
    >> internal layers .ly2 and .l15 with above Eagle layer definition. No idea
    >> that that was wrong. Will investigate.
    >> Robert
    I suspected that. Maybe a future cam proc could warn about data in copper
    layers that isnt associated with a job?
    Regards, Robert
    >>> layer
    Robert
    >> layer
    the internal layers .ly2 and .l15 with above Eagle layer definition. No
    idea that that was wrong. Will investigate.
    Robert
    layer
