EAGLE User Support (English) Design Reuse
  • Views 750 views
Design Reuse
I'm not sure if cadsoft has implemented the copy/paste for sch+layout at
last.
I'm talking about duplicate a section of a schematic without loose the
placement and routing information.
Reading through the new features doesn't help me.
Do we still need to do the nasty workaround of closing schematic and
capture one at time to fool the fb annotation?
Marco
    Il 27/12/2011 22:43, Jorge Garcia ha scritto:
    Hi Marco,
    Use the Paste from... feature which was implemented in V6. This is why
    you upgraded to v6.
    This feature allows you to import a consistent schematic/board pair into
    your current design. It does require you to have a version of EAGLE that
    will allow for more than one schematic sheet.
    Jorge,
    thank you very much for your answer.
    I was able to import the sch/brd pair. I have a PRO license so no
    problem about multiple sheets.
    I didn't find this command because - as usual - cadsoft complicates
    simple things... I was looking how to copy/paste a section of circuit
    within the same file!
    This solution works, but you have to create a separate project for each
    section you want duplicate.
    IMHO the best should be: select whatever you want and use a
    "paste-with-layout" command. For example every word processor offers the
    paste-with-format, paste-without-format, paste-plain-text...
    Anyway thank you again
    Marco
    On 12/28/2011 5:32 AM, Joern Paschedag wrote:
    Maybe you should mention that this "Paste from..." item is available in
    the "Edit" menue (or whatever name it is in english) only. Also the help
    shows imo little way to find it.
    Thanks Joern,
    These are the evils of assuming too much. Hopefully with your
    clarification the user can find what he needs.
    Best Regards,
    Jorge Garcia
    Am 27.12.2011 22:43, schrieb Jorge Garcia:
    >> It seems it doesn't work anymore. It messes up the part names and it
    >> takes too long to rename manually each component.
    >> I hope I didn't waste my money again image
    >> The possibility to reuse my layout is why I upgraded to V6. By the way
    >> it has a lot of bugs, why?
    >> Marco
    Hi Marco,
    you upgraded to v6.
    hth,
    Jorge Garcia
    Joern Paschedag
    Marco
    Hi Marco,
    you upgraded to v6.
    hth,
    Jorge Garcia
    "Marco Trapanese" <marcotrapaneseNOSPAM@gmail.com> wrote in message
    news:jd9c83$jk3$1@cheetah.cadsoft.de...
    It seems it doesn't work anymore. It messes up the part names and it takes
    The possibility to reuse my layout is why I upgraded to V6. By the way it
    Marco
    You can try the Renumber Sheet ULP and start the renumbering at 100, 200, or
    whatever is necessary to insure that there is no overlap of designators. You
    still have to close and open the files just as before (and keep your fingers
    crossed).
    I haven't tried this with ver.6 but it worked with ver.5 when I needed to
    combine two projects into one PCB.
    B
    Marco
