EAGLE User Support (English) HOW TO INVERTING PCB LAYOUT?
  • Replies 12 replies
  • Views 3425 views
HOW TO INVERTING PCB LAYOUT? for printing in negative mode image
    Guest wrote:
    On 1/3/2012 4:10 PM, ali mahdi wrote:
    Ali,
    There's no need for that, what do you plan to accomplish other than
    getting your message ignored? Jason is trying to help you out and I've
    replied to your e-mail request with a feasible solution.
    Best Regards,
    Jorge
    I don't think it was aimed at me - unless he thinks I'm an Eagle developer.
    In any case, it's not very nice, and I'm very disinclined to offer any more assistance in this area (and if I was an Eagle developer, then I would certainly feel that lowering the priority of this feature is justified).
    I know how I'd invert the image, but if the reason why the scaling is wrong is in the latter stages of output (i.e printing), then I know it won't work so there's no point in suggesting it.
    Ali,
    Best Regards,
    Jorge
    [deleted]
    Is it a photographic process (i.e. you need to provide it with a negative)? If so, how are you producing the photographic material? Is it printed out somehow?
    (I'm just trying to gauge why you're having problems with scaling, and where those problems can lie).
    yes
    So you make the solder mask/silk screen yourself?
    thank you Jason Tribbeck
    i use invert  pcb solder mask for silkscreen printing and it very important
    and any other pcb desgine programe have inverting layout. but eagle not . why !!!!!!!!!!!!!1
    Is there any particular reason why you need to invert the PCB image? And how are you producing the mask from the file?
    If you're using a printer driver, then you need to make sure that this isn't scaling the output (such as having a "fit to page" option selected).
    I regularly use the PDF export option, and import it into a program which does PDF reading, annotate it with my name, design name, logo and so forth, and then print it using a normal inkjet printer. But then I spent a lot of time making sure that the scaling wasn't a factor (however, I've never needed to invert the image)
    thank you for helping me.
    i try
    1- gerber file and then inverting it.
    2- ps-inverted.
    3- image inverted
    4-pdf  inverted
    but all not in same scale size !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    there are an error in scale.
    and when i print it by silk screen solder mask i loss alot of money.
