EAGLE User Support (English) Screen size "jumps" when tools are selected
  • Views 373 views
I noticed in v 6.0 that now the screen size jumps when I select
certain tools.  It is because of a change in size of the second
toolbar row - the one that shows the line thickness when you are
placing a line. This toolbar is adaptive.  It shows the relevant
options for whatever tool you happen to select.  And in some of those
adaptation, the toolbar ends up being higher than in other
adaptations.  These changes in toolbar height propagate to the main
display area and cause the jump.  I don't think v5.x did this.
The easy work-around that I found was to undock that adaptive toolbar
and move it to near the bottom of the main display screen.  When it is
a floating toolbar it can change size and not affect the size of the
main display area.
Robert Scott
Real-Time Specialties
Ypsilanti, Michigan
    Just to chime in -- I notice this subtle screen resizing behavior as well on my Windows 7 machine, 1920 x 1080, and it appears related to the Eagle toolbar when certain icons appear.
    On Wed, 04 Jan 2012 16:36:38 +0100, Richard Hammerl
    >> main display area.
    >> Robert Scott
    >> Ypsilanti, Michigan
    >I don't notice this on my Linux system here. What OS do you use
    >and maybe do you use some special settings concerning the display?
    I am using Windows 7 with a 1920x1080 LED monitor.  I don't recall the
    exact display settings and I am not on that computer right now.
    >Mit freundlichen Gruessen / Best regards
    >Richard Hammerl
    Robert Scott
    Ypsilanti, Michigan
    main display area.
    Robert Scott
    Ypsilanti, Michigan
    Richard Hammerl
