EAGLE User Support (English) DWG to Gerber translation
  • Views 1309 views
I need to do some Gerber exports of older board files that were originally
drawn in AutoCAD. If I recall properly, there was some ulp to import dwg or
dwf files into eagle (5.11). Would appreciate if anybody has a process for
this that will preserve layers.
tia - Bob Oppenheimer
    "Richard Hammerl" <support@cadsoft.de> wrote in message
    news:je4gsa$3dk$1@cheetah.cadsoft.de...
    You could try dxf2scr-1.zip in the misc folder (tools and converters).
    Tried it and after remembering how to explode all objects in the AutoCAD
    file, was able to run dxf2scr-1.exe. Like import_dxf_polygons.ulp there is
    no layer import setup and anything imported will show up on the same layer
    (20). Text was not imported at all??
    So far (imho) the Eagle Power Tools suite provides the best solution. Not
    perfect but very good as the layers are all preserved. I still have to go
    through the drawing and update what imported as vias recheck connectivity.
    Cheers - Bob
    autodeskguest over 14 years ago in reply to e14 Contributor
    Cheers - Bob
    "Oppie" <oppie@saynotospam.com> wrote in message
    news:je4e60$oum$1@cheetah.cadsoft.de...
    Just remembered that the company bought an Eagle Power Tools license.
    Tried the DXF => EAGLE Script Converter 2.3.3
    Going to take a little time to get the hang of it but it uses a layer
    definition file to import the layers from DXF to a given layer in Eagle. Got
    to refine my setups but it seems to do what I need for now. Then once it's
    in Eagle I can use my standard CAM output processes.
    Cheers!
    news:je1rou$7u2$2@cheetah.cadsoft.de...
    >>> originally drawn in AutoCAD. If I recall properly, there was some ulp to
    >>> import dwg or dwf files into eagle (5.11). Would appreciate if anybody
    >>> has a process for this that will preserve layers.
    >> Can you export DXF? If yes, there are tools to convert this into
    >> EAGLE script format. Please look into the Download area, Converters
    >> and Tools.
    Thank you Richard
    Yes, I can get a dxf.
    I downloaded"import_dxf_polygons.ulp"
    Looks like it wants to import the entire dxf to one layer. Is there a
    better program that will import all layers of an autocad drawing into
    eagle while preserving layer information? ...or do I make separate dxf
    files with only one layer active at a time and then import each of these
    to a given layer with the import_dxf_polygons tool?
    HTH
    Richard Hammerl
    and Tools.
    Thank you Richard
    Looks like it wants to import the entire dxf to one layer. Is there a better
    program that will import all layers of an autocad drawing into eagle while
    preserving layer information? ...or do I make separate dxf files with only
    one layer active at a time and then import each of these to a given layer
    and Tools.
    Richard Hammerl
