EAGLE User Support (English) Version 6.1
  • Subscribers 189 subscribers
  • Views 561 views
Version 6.1
Gustav_M
Gustav_M over 14 years ago
Hi
When is the next version of Eagle released? I guess that there will be a
bug-fix release... is that correct??
Best regards,
    e14 Contributor over 14 years ago in reply to Gustav_M
    On 1/9/2012 5:04 AM, Gustav wrote:
    Jorge wrote:
    The next update of EAGLE will definitely be a bug-fix release. I don't
    have an ETA on it yet.
    Well, are we talking 1 week, 1 month or half a year? I am asking because
    version 5.11 is very stable and I don't want to risc anything.
    Hi Gustav,
    If stability is a concern, stick with V5 for the moment, until the next
    update is released. ETA stands for Estimated Time Arrival, what I was
    trying to say is that I don't know when the next update will be released.
    Hth,
    Jorge Garcia
  • Gustav_M
    "Martin Eder" <martine001@verizon.net> wrote in message
    news:je5i2d$23j$1@cheetah.cadsoft.de...
    "Brett Holden" <bretth2o@bellsouth.net> wrote in message
    news:je4ure$ogq$1@cheetah.cadsoft.de...
    >> "Jorge Garcia" <jorge@cadsoftusa.com> wrote in message
    >> news:je4u2l$kvf$1@cheetah.cadsoft.de...
    >>> On 1/5/2012 11:03 AM, Gustav wrote:
    >>>> Hi
    >>>> a
    >>>> Best regards,
    >>> Hi Gustav,
    >>> hth,
    >>> Jorge
    >>> Cadsoft Support
    >> My installation has crashed so many times in the past couple of days... I
    >> feel like a crash test dummy. Eagle 510 was stable. Version 6.0 not so
    >> much. ;(
    If I upgrade to 6, will I be able to run 5 while waiting for a 6 bug fix
    to be released?
    You should  make use of the -new- ability to have seperate eaglerc.usr files
    for different installations. You can supposedly either rename the v6 erc
    file or else locate the file in a different location, thus continuing to use
    v5 and not have v6 interact with it by writing to a single eaglerc.usr
    file - as was previously the case.
    I failed in my attempt to rename v6 erc file and run it from the 'default'
    location, however I was able to successfully force a new location for the v6
    file eaglerc.usr.
    Read the Update notes and v6 manual, and search on "-U" and you will find
    the (scant) documentation for this feature.
    Look for my recent complaint in the suggestions forum and you will be able
    to read the same helpful hints that I used for figuring out how to run v5
    and v6 side-by-side.
    >>> Hi
    >>> be a
    >>> Best regards,
    >> Hi Gustav,
    >> don't have an ETA on it yet.
    >> hth,
    >> Jorge
    >> Cadsoft Support
    days... I feel like a crash test dummy. Eagle 510 was stable. Version
    6.0 not so much. ;(
    to be released?
    >> Hi
    >> Best regards,
    Hi Gustav,
    hth,
    Jorge
    Cadsoft Support
    feel like a crash test dummy. Eagle 510 was stable. Version 6.0 not so much.
    Hi
    Best regards,
    Hi Gustav,
    hth,
    Jorge
    Cadsoft Support
