EAGLE User Support (English) How to use Meander in Eagle 6.0.0
  • Subscribers 189 subscribers
  • Views 2961 views
I cannot figure out how to use meander, can anyone help! If I have 2 traces, 1 trace is 5 inches, and the other is 4 inches, how do I make the second trace 5 inches long?
  • Dusan_R
    Dusan_R over 14 years ago in reply to e14 Contributor
    You can simplu type the length after selecting the command (same way as with for example wire width while routing). I am using text commands, not the icons, but with icon it works the same way - click on icon, then type the parameter.
    Craig Beiferman wrote:
    I am confused, I click on the meander icon, and there is no popup for
    a desired length? How do I enter the parameter?
    Hmmm! Does it not work how the manual describes?
    Manual is found in the doc folder of your installation.
    HTH
    Warren
    news.cadsoft.de
    e14 Contributor over 14 years ago in reply to Dusan_R
    I am confused, I click on the meander icon, and there is no popup for a desired length? How do I enter the parameter?
  • Dusan_R
    Hi Craig,
    simply invoke Meander with parameter giving the desired length (here 5 in), click on the shorter track and the window with desired length and the actual percentage of itappears. Now simply move the pointer to place the meander as desired. Well desribed in help.
