EAGLE User Support (English) New Restrict Layer
  • Views 397 views
  • eagle
  • help
  • restrict
  • pcb
  • flood
  • polygon
  • layers
New Restrict Layer
Hi all,
I am currently laying out a four layer PCB and need a large flood plain for heat purposes so need to use the maximum area of the board I can. but due to clearance and creepage distances with via's, drawing lots of flood plains to accomodate the various clearances needed isn't really viable (see what I did there?)
My thought was instead to draw a restrict boundry around the components in the library editor but there is only restrict layers for Top and Bottom.
So my question is, how can I create a restrict layer that corresponds to one of my new layers?
Just in case you're wondering, I need the two restrict layers as well as another one so I can't just change one.
Rich Long
    Hi Warren,
    Yeah I have looked at the manual. Since I posted I discovered on a forum that is isn't possible to create a new restrict layer so I had to make numerous polygons to maximise the surface areas whilst satisying clearance distances!
    Thanks for your reply anyway
    Rich
    Richard Long wrote:
    Hi all,
    needed isn't really viable (see what I did there?) My thought was
    I feel you are approaching this wrongly.
    Have you reviewed the manual, Section 6.3."Defining a Copper Plain with
    POLYGON"
    HTH
    Warren
    news.cadsoft.de
