EAGLE User Support (English) Setting schematic net line width default ?
  • Views 1391 views
Greetings - I know I can go in and change the line width of a line on the
schematic, but is there a way to set the default line width for the "net"
line to a different value ?  The default seems to be .006 and I would
prefer to use a thicker line - more like .012 (it looks better on the 8-1/2
  • 11 sheets )
mikey
    Ah, thanks much - I had snooped around in the options etc, but had not come
    across that.  It is indeed a tradeoff - looking neat vs TOE  (These Old
    Eyes) and just a couple of mils thicker makes the schematic much easier to
    read.
    mikey
    Am 24.01.2012 07:37, schrieb Mike Fields:
    • 11 sheets )
    mikey
    Check eagle help Configurating eagle. Check for SET NET_WIRE_WIDTH
    (value). Remember if you use a larger value, the connection to a
    resistor etc. may look ugly.
    Joern Paschedag
