EAGLE User Support (English) Global Document # And Rev Level
  • Views 397 views
Is there a way to set the document # and rev level of a schematic once,
and have it appear in the title boxes of all of the frames?
I'm thinking of something like the capability one has in Word or
OpenOffice, to set a global document property, then have a field that
displays that property anywhere in the document.
I'm using the 'TABL_L' frame, just in case it's already implemented and I
just need to set something...
My liberal friends think I'm a conservative kook.
My conservative friends think I'm a liberal kook.
Why am I not happy that they have found common ground?
Tim Wescott, Communications, Control, Circuits & Software
http://www.wescottdesign.com
    On Tue, 07 Feb 2012 20:18:47 +0100, René König wrote:
    Hi Tim,
    here is an example for the rev level:
    - Open frames.lbr
    - edit docfield.sym
    - place the text ">REV" somewhere within the symbol - open a schematic
    and execute "update frames" command - add a global attribute named REV
    to the schematic
    The symbol's place-holder ">REV" should be replaced with the attribute's
    value now. The procedure for the document number is the same, only
    choose a different name for the attribute.
    Please keep in mind, that your changes to the library get lost with the
    next EAGLE update. Better copy the frames-library to your private
    library directory and do the changes here.
    Rene:
    Thanks, that's exactly what I was hoping for.
    I don't modify the EAGLE libraries at any rate -- I use my own private
    copies for any different stuff.  This'll be perfect.
    Hi Tim,
    - Open frames.lbr
    - edit docfield.sym
    - open a schematic and execute "update frames" command
    - add a global attribute named REV to the schematic
    Rene
