EAGLE User Support (English) Eagle 6.1.0 Unattended Install
  • Replies 12 replies
  • Views 1671 views
I maintain the installs on our University owned machines.  I need to deploy this software to around 50 machines, and will periodically need to update this to newer versions.  I have the license and the installer already, but I'm running into issues automating the install process.
I noticed that your self extracting exe unzips and then runs "bin/eagle.exe --setup", which is fine, but I'm not able to figure out how to pass any of the inputs for scripted installs.  It appears that all the --setup command does, is take a couple of inputs, and then copies itself into the target location, and create two files: eagle.key, and uninstall.lst.
I have a feeling that I could install it onto one computer, and then copy the install onto other computers, while adding the 4 Registry keys, and the 5 start menu shortcuts, but I'd rather do it through officially supported means.
Is there any method provided by CadSoft for unattended/silent installs?
ECEHelp
    Il 13/03/2012 20:57, Jorge Garcia ha scritto:
    I agree with you and thank you for your courtesy. We did our best with
    the initial release, I don't think any one would release faulty software
    intentionally.
    I don't want to make excuses, there were many factors involved and as it
    turns out V6.0.0 was not as ready as we would have liked. It is what it
    is and we're working on fixing it.
    The goal is always for a new release to be as robust as possible, but
    that didn't happen so now we have to get it back to were it needs to be.
    Thanks for your kind answer.
    Marco
    On 3/13/2012 4:44 AM, Marco Trapanese wrote:
    Just to understand, no polemics at all.
    Why sell v6 with all that bugs? I can't believe they didn't know before!
    You might discover most of them after few minutes of normal use.
    IMHO the goal should be release EAGLE versions when they have the
    robustness they're known for, rather than "to get them back to".
    Of course there will always be some bugs, in any applications. But it
    would be better if Cadsoft had released the v6.1.3 at first, after some
    tests.
    We're talking about a professional application, not a flash game image
    So, the question is: why?
    Marco
    Hi Marco,
    intentionally.
    Jorge Garcia
    Cadsoft Support
    Am 13.03.2012 14:20, schrieb Andrew Sterian:
    To be fair to Cadsoft, they did do a lot of beta tests (conducted
    through this newsgroup) and in exchange for providing a free look ahead
    they expected testing and feedback. They got some, but not enough to
    make 6.0.0 as robust as possible. This is not new...the same thing
    happened with Eagle 5.0.0. IIRC it wasn't really "good" until about
    version 5.6.0 or so.
    Exactly. Version 5.6 was the one that was OK enough to let loose on our
    students here (before that, lots of ULPs that people here rely on didn't
    work properly due to bugs). For people NOT used to special ULPs, earlier
    versions surely also did their job.
    Those of us that have been around since v3 know how this works and do
    not hold Cadsoft to an unreasonable standard of quality given the cost
    of the tool: you treat version x.0.0 as a "second beta", kick it around
    a little bit, wait until the flurry of changes dies down to a low
    murmur, then consider it stable.
    Yes, but this works only for die-hard customers like us who KNOW that.
    People new to EAGLE and checking out whether it's worth buying DON'T
    know that and might shy away from buying given an unusual amount of bugs.
    Andreas Weidner
    On 3/13/12 4:44 AM, Marco Trapanese wrote:
    Il 12/03/2012 19:10, Jorge Garcia ha scritto:
    >> Why not just start exercising V6 and get those issues found out and
    >> corrected. Our developers are working tirelessly to get bugs corrected
    >> and fixed, their goal is to get EAGLE back to the robustness it's known
    >> for as soon as possible.
    tests.
    Marco
    I don't fault them for this. If you look at the bugs that are being
    fixed, most "light usage" designers would never notice them, or similar
    bugs in other programs would be equally tolerated by the public. This is
    the niche that Eagle fills: a cut above freeware/open source/web-based
    schematic editors, in which what you get is what you get and you don't
    get to complain about the bugs, and a big $$$ cut below the big names in
    which you expect glitzy polished behavior (and I bet they have their
    share of bugs too, probably not acknowledged or supported in a newsgroup).
    Getting a cross-platform CAD program to have 0 bugs costs a lot of time
    and money, and personally I'm happy that Cadsoft spends LESS time and
    money up front and charges LESS money for the tools as a result, as long
    as they get the program to EVENTUALLY have as close to 0 bugs as
    possible in a reasonable amount of time, while relying on customers to
    a) tolerate the bugs, and b) report the bugs.
    Andrew.
    tests.
    Marco
    On 3/12/12 2:10 PM, Jorge Garcia wrote:
    On 3/10/2012 2:55 PM, Warren Brayshaw wrote:
    When
    >> that group starts to exercise v6 expect many more issues to be found.
    >> Warren
    I had my share of problems with v6 but have completed two designs with
    v6.1.3 and I think it's good enough to stick with. It still has some UI
    quirks on Mac OS X (screen "jumps" when switching from board to
    schematic, some toolbar buttons are not highlighted when selected) but
    it's usable and generates good data as far as I can tell.
    So from my point of view, v6 has "turned the corner" towards stability
    and I'm going to start all new designs with it.
    Andrew.
    When
    >> Warren
    How can that goal be met if the experienced users don't attack V6. I
    think it's a disservice to the EAGLE community in general not to
    exercise it.
    I'm not saying to risk your critical work if you don't feel comfortable,
    but use it, make some hobby projects with it exercise it. If you compare
    6.0.0 to the latest beta 6.1.3 I think you'll be able to see the amount
    of effort that has gone to bring it back to a level that "justifies"
    it's use and the commitment towards are users to produce a product that
    helps them get work done.
    This is not a personal shot at anyone, but I've noticed a similar
    sentiment in other posts, and I just don't feel it's productive to
    getting EAGLE back to the robustness we all expect and need.
    Just my 2 cents,
    Jorge Garcia
    Sorry for the typos, I humbly request that these be looked over.
    Best Regards,
    Jorge Garcia
      When
    Warren
    exercise it.
    Just my 2 cents,
    Jorge Garcia
    Am 08.03.2012 18:21, schrieb ECE Help:
    As a matter of fact, that is EXACTLY what can be done (we do this since
    years):
       1. Install it on ONE machine (your reference).
       2. Afterwards, just deploy EAGLE by copying all the reference
          files to other machines (prefereably into a folder where
          the user has WRITE access, otherwise there'll be problems
          when running EAGLE later).
       3. (Cannot be avoided) When starting EAGLE the first time, every
          user must enter your license key.
       4. Adding registry keys is ONLY necessary if the users like to
          be able to double-click on EAGLE files to open them.
       5. Same is valid for the menu shortcuts.
    This even works for multiple operating systems: All EAGLE files for
    Windows, Linux and Mac can reside on ONE system (we use a samba server
    here), even without any useless duplication of libraries etc.
    Additionally, in order to keep already existing EAGLE installations
    up-to-date, I can provide you with an update program (for all three OSs)
    that the users can start themselves: This program can check a (remote)
    server for your reference installation and then update all local files
    with newer ones from the reference repository.
    If you're interested in this, send me a valid e-mail address, and I can
    give you more details.
    Andreas Weidner
    >> This has nothing to do with your problem and is a bit off topic, but
    >> a word to the wise:
    >>   If you don't want to hate yourself later (and you do want the
    >> students at your institution to like you) do not waste time with
    >> version 6.1.0.
    >> Take a look at the bug fix list for v6.1.2 and maybe you'll
    >> understand why I say.
    Make it 6.1.3 image
    Joern Paschedag
    I recommend not getting involved with version 6 right now. Stay with v5.12
    As a generalisation, those  currently reporting faults with v6 are low time
    users. The longer time experienced users are currently not posting defects.
    I suspect that they are, like me,  not wasting time with v6 until it reaches
    a standard that justifies the time it takes to evaluate it properly. When
    Warren
    news.cadsoft.de
