EAGLE User Support (English) Eagle 6.1.0 Design Link SSL error
  • Subscribers 189 subscribers
  • Views 404 views
silvio80
silvio80 over 14 years ago
Good Morning,
As other users I found a problem in the use of Design Link with Eagle 6.1.0.
Specifically:
Error while entry has 'https://uk.farnell.com/pffind/services/SearchService':
6 SSL handshake failed
I performed testing on different computers and different ISPs, but the problem persists.
On the same machines, Eagle 5.1.1 Design Link works perfectly.
Waiting for reply, Regards
                                        Silvio Roagna
    e14 Contributor over 14 years ago in reply to silvio80
    On 3/10/2012 1:04 PM, Silvio Roagna wrote:
    Thank you, Mr. Jorge
      as your suggestion I checked again the settings of firewalls, routers and proxies. I confirm that Design Links on Eagle 6.1.0 still doesn't work, while, on Eagle 5.1.1 works correctly.
      I await the response from developers.
    For more infos, i used on XP sp3 and win7 64 bit PCs.
      Regards
                    Silvio Roagna
    Hi Silvio,
    Our developers got back to me and confirmed that the SSL error you're
    experiencing is due to the Qt Libraries we use. They looking to see what
    they can do about it in version 6.1.4.
    hth,
    Jorge Garcia
  • silvio80
    silvio80 over 14 years ago in reply to e14 Contributor
    Regards
                   Silvio Roagna
    On 3/8/2012 9:03 AM, Silvio Roagna wrote:
    Good Morning,
    Specifically:
                                             Silvio Roagna
    Hi Silvio,
    I have notified our developers, let's see what they get back with. If
    you are behind a firewall I would recommend disabling it for a moment
    and trying designlink just to see if the firewall has something to do
    with it.
    Best Regards,
    Jorge Garcia
