EAGLE User Support (English) Mouser Part Library for Schematic Design
  • Subscribers 189 subscribers
  • Views 1385 views
I've got a project that requires me to recreate a PCB that has Mouser branded parts.  Eagle doesn't have a Mouser library as far as I know.  This is kind of a first for me.  What are my options?  Using equivalent parts in the default labraries?
P/N
QTYDiameter hole
3103-2-00-00-21-00-00-08-0Mouser5Pins.043" mounting hole min
583-RL1N4004Mouser2D1,D2component dia 0.025
78-1N5239B-TAPMouser1Z10.025
652-RLB1014-104KLMouser1L10.025
581-TAP334K050SCSMouser1C10.02
229-330-RCMouser1R10.02
652-3309W-2-102Mouser1R2
  • rusgray
    rusgray over 7 years ago
    Those are all ordinary through-hole parts. Just look up the part numbers at Mouser, then pick appropriately-sized footprints from the "diodes" and "rcl" libraries. If you can't find exactly what you need, you can make your own footprints in EAGLE very easily. If you plan to do any significant amount of PCB design work, you will certainly be making your own footprints, so it's never too early to start learning.
    Am 13.03.2012 03:16, schrieb bobdude161:
    I've got a project that requires me to recreate a PCB that has Mouser branded parts.  Eagle doesn't have a Mouser library as far as I know.  This is kind of a first for me.  What are my options?  Using equivalent parts in the default labraries that are normally Mouser?
    | P/N  |   | QTY | Diameter hole |
    | 3103-2-00-00-21-00-00-08-0 | Mouser | 5 | Pins | .043" mounting hole min  |
    | 583-RL1N4004 | Mouser | 2 | D1,D2 | component dia 0.025 |
    | 78-1N5239B-TAP | Mouser | 1 | Z1 | 0.025 |
    | 652-RLB1014-104KL | Mouser | 1 | L1 | 0.025 |
    | 581-TAP334K050SCS | Mouser | 1 | C1 | 0.02 |
    | 229-330-RC | Mouser | 1 | R1 | 0.02 |
    | 652-3309W-2-102 | Mouser | 1 | R2 |
    Mouser is a distributor but not a manufactorer. Do you expect a layout
    programm to support every distributor in the world?
    Get the datasheets from the manufactorers and if the parts are in the
    eagle default libraries then move them into a new library. You can call
    that mouser or whatever you want image
    Joern Paschedag
