EAGLE User Support (English) grab part in PCB 6.10
  • Subscribers 189 subscribers
  • Views 638 views
rickford66
rickford66 over 14 years ago
I'm wondering if there is a special command to grab a part in PCB.  For example, I would type SHOW U1 and Eagle would highlight U1 so I could find it.  Rather than hunt for every part to move them onto the PCB, is there a command that will cause the part to become attached to my mouse pointer as if I was moving it?  I've used FIND U1 before.  That actually works sometimes.  I haven't figured out why it only works simetimes, but Eagle complains everytime that it's not a valid command.  Thanks.
    Try   SHOW @ U1   and EAGLE points to the part.
    Richard Hammerl
    e14 Contributor over 14 years ago in reply to rickford66
    rickford66 wrote:
    >Nevermind.  After I wrote the question, it occurred to me to try MOVE.  That worked.  haha
    see below for a small ULP that will pick up parts in the board, that
    have been grouped in schematic
    #usage "%.1fmic %.1fmic)", u2mic(mx/gCnt),
    u2mic(my/gCnt));
          if (project.schematic) cmd = "edit .brd;" + cmd;
          exit(cmd);
    Lorenz
    Craig Beiferman schrieb:
    P.S. All the commands usually have a 2 letter equivalent, so you can
    type "MO U6" to move U6
    This is not really exact.
    You can abbreviate all commands as long as they are unambiguous -
    otherwise, the first match will be taken (in alphabetical order).
    Examples:
    V     VIA
    D     DELETE
    M     MARK
    MI     MIRROR
    MIT     MITER
    MO     MOVE
    T     TECHNOLOGY
    TEX     TEXT
    The command list in the HELP is useful for finding the shortest possible
    abbreviation.
    Tilmann
  • rickford66
    rickford66 over 14 years ago in reply to e14 Contributor
    That will save some time over lots of parts.  Thanks.
    P.S. All the commands usually have a 2 letter equivalent, so you can type "MO U6" to move U6
  • rickford66
