EAGLE User Support (English) 6.20 Mac Part Search
  • Subscribers 187 subscribers
  • Views 297 views
jtowich
jtowich over 14 years ago
6.20 Macintosh part search doesn't seem to be working well. The first search works, but then hitting the "x" icon won't get rid of the search. Dropping the items will get rid of the search, but then all subsequent searches come up with nothing until Eagle is restarted.
    autodeskguest over 14 years ago in reply to autodeskguest
    Hi Joe,
    Drop removes libraries from the active search list,definitely not what
    you want. To get all of your libraries back type the following in the
    command line:
    USE * <enter>
    where <enter> means pressing the enter key on your keyboard. This will
    bring all of your libraries back into use.
    You don't have to get rid of the search just type in the new part
    you're looking for and press enter. It's a good idea to make liberal
    use of eagle's wildcard character(*) when looking for parts. For
    example don't search for LM555 you won't get any hits, but it is there,
    instead search for 555 and in the linear library you'll find the part
    you want.
    What I do when I want to get all of the libraries back is search for *,
    and then click the icon to the left of search field pack up the
    libraries.
    hth,
    Jorge Garcia
    Cadsoft Support
    Thanks for the info on drop. It seems to be ok now, but when I was
    using it yesterday the x icon to the left of the text field was doing
    nothing. The search field and search results were not being cleared.
    That is why I tried the drop button. That messed things up more I
    suppose.
    Not sure how I got it in that mode, if it happens again I will try to
    repeat and let you know.
    Joe
    Hi Joe,
    command line:
    USE *  means pressing the enter key on your keyboard. This will
    You don't have to get rid of the search just type in the new part you're
    looking for and press enter. It's a good idea to make liberal use of
    eagle's wildcard character(*) when looking for parts. For example don't
    search for LM555 you won't get any hits, but it is there, instead search
    for 555 and in the linear library you'll find the part you want.
    and then click the icon to the left of search field pack up the libraries.
    hth,
    Jorge Garcia
    Cadsoft Support
