EAGLE User Support (English) ULP for searching/zooming
  • Subscribers 189 subscribers
  • Views 305 views
  • ulp
I want to make a ULP so that I can hit ctrl-F, type in a reference designator, and have the board or schematic (ideally both) select the part with the editor's SHOW command and, if possible, center the window on that component.
Possible?
string name = "";
     int result = dlgDialog("Hello") {
     dlgStringEdit(name) dlgAccept();
     dlgHBoxLayout {
          dlgPushButton("+OK") dlgAccept();
          dlgPushButton("Cancel") dlgAccept(2);
if(result == 0) {
     /* somehow execute SHOW name and recenter board and schem on this part ??? */
    DOH!
    Thanks, I hadn't noticed that.  I will snag the pan and zoom part out of that.  Thanks again.
    --Chris
    There is already the Find.ulp you can map to ALT+F.
    Under Options, click Assign, then New. Select F as your key and Alt as your Modifer
    Then type "run find" under Assigned command
  • anweid
    anweid over 14 years ago
    Am 17.04.2012 17:51, schrieb Christopher Piggott:
    Possible?
    Yes. But don't program that yourself, because there are at least two
    ULPs that already do that:
      1. CadSoft has programmed a ULP 'find.ulp' that does that, and which
         should already be in your ULP folder.
      2. Find attached MY 'find' ULP, which can search for LOTS of things,
         including MATHEMATICAL values (so searching for '1k' could also
         find '1000R', '0.001M', '1k/0.1%' etc.) and width ranges (e.g.,
         you can search for widths '<0.2mm' or so), including wildcard
         support etc.
    I'm in the process of updating this ULP, so you cannot only SEARCH for
    things, but also SELECT things from out of all available objects. In the
    next weeks, the new version will be available, but for now, use the
    attached old one. Feedback is welcome.
    Andreas Weidner
    find.zip
