EAGLE User Support (English) Stop Mask DRC Errors when visible
  • Views 328 views
Normally the stop mask layer (29) is not visible.  But when I made it
visible with View /Display-Hide Layers then ran the DRC, it came up
with a zillion stop mask errors - essentially everywhere there was a
stop mask.  Turn off visibility and no more errors.  Why does making
the stop mask layer visible affect whether or not there is an error?
I am using Eagle 6.0 on a Windows 7 computer.
Robert Scott
Ypsilanti, Michigan
    the stop mask layer visible affect whether or not there is an error? I
    Robert Scott
    Ypsilanti, Michigan
    DRC is checked mainly on the active/visible layers, so that if you do not
    care about stop mask VS silk errors (for ex. if you do not print the part
    names) then you are not annoyed by these errors.
    Jerome
