EAGLE User Support (English) Change attributes in properties box
  • Subscribers 189 subscribers
  • Views 742 views
    e14 Contributor over 14 years ago in reply to CSWalt
    don't forget there's also the attribute command in the context menu of the part/element !
    Changing it this way is almost as convenient I think.
    Walter Spermann
    I know. But right know it's an inconsequent break in workflow.
    I'm allowed to change almost everything from within the property context
    menu, like coordinates, Name, Value, Rotation, lock, smash, unlock etc
    which is very effective and quick without the need of selecting the
    corresponding tool first, but I'm forced to leave this powerful facility
    for just changing some attribute's value.
    I'm sure it will save tons of time when one could do all the changes he
    wants in this single window and then just hit OK and you're done.
    Just my 2 cent (after changing attributes of a project with ~300 parts
    today I might be biased, but every click saved would have paid off
    today....)
    I also think it's not very difficult to implement and I think usability
    will gain a lot.
    Markus
  • CSWalt
    CSWalt over 14 years ago in reply to e14 Contributor
    On 04/24/12 19:05, Markus Rudolf wrote:
    Am 04.05.2009 11:21, schrieb Morten Leikvoll:
    >> In the list of attributes, I'd like to doubleclick the attributes in the
    >> list to change value..
    Oh yes PLEASE image
    The current concept is a pain in the beep.
    I often copy parts e.g. resistors, with all my custom attributes, and
    often there is need of partly changing attribut values.
    I for instance have attributes for SUPPLIER, ORDERCODE, MOQ, PRICE and
    need to change only minor details.
    Instead of just right-clicking the part, I have to switch to the
    attribute tool, select the attribute, change value and so on.
    Walter Spermann
    If I could just edit the attribute's values in the property context menu
    and save, this would make life so much easier.
    I think any property should be directly editable from there.
    Markus Rudolf
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    Oh yes PLEASE image
    Markus Rudolf
