EAGLE User Support (English) Improvements to "Attribute" Dialogue
  • Views 233 views
While reflecting why I actually wanna have the "attributes" in the
property dialogue of a part editable directly in the property dialogue
itself, I actually found out what annoys me most on the current
"attribute" dialogue.
That is, for simply changing a value in an already populated list, you
have to select the line with the value you wanna change in it,
doubleclick it, which leads to the opening of a sub dialog where I again
have to select the value, edit it, select if I wanna have it visible or
not and so on.
This would be much more easy if you could just type directly in the
dialog and just tick the corresponding checkboxes if you wish to have
them visible.
I made a mockup dialogue how I imagine this could look like.
Maybe there could be a "All Names visible" and "All Values visible"
button to check/uncheck all boxes in the corresponding columns.
95% of all time I edit attribute values that have been pre-created for
each part with a script in advance, so the focus of the dialogue should
be more on make changes easy, than on make creation of the attribute
structure easy (e.g. add new attributes).
Markus Rudolf
  • CSWalt
    CSWalt over 14 years ago
    not and so on.
    them visible.
    Markus Rudolf
    That's a good idea for schematic and board attributes
    but does not fit for library atribute dialog. There we have a matrix of combinations.
    Anyway thanks for your suggestion !
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
