EAGLE User Support (English) Schematic select PCB move
  • Subscribers 189 subscribers
  • Views 659 views
I have a Schematic with a large component count. Is it possible to group
select in the schematic view and then group move ( for placement ) in
the layout view. Also may I suggest that it would be preferable to have
the components mimic the placement on the schematic rather than having
long lines of components that have no real value, even if these
components were to be placed next to or over one other, Typically most
boards layout would mimic the schematic order in some form even if it is
just in groupings.
Jannie du Preez
    Thank you all for your help
    I was under the incorrect impression that this forum was supported, paid
    for or run by eagle staff. With this information I am now so much more
    appreciative off what you guys offer here as a service.
    As for apg.ulp, it does not function which does not surprise me as my
    schematic is spread over 6 different sheets. I will look at the
    scripting option mentioned by Chuck. Though this will be a learning
    curve for me as I have not yet used the scripting.
    Kind regards
    Jannie
    , On 2012/05/02 07:50 AM, Lorenz wrote:
    Jannie wrote:
    >> Could someone please assist me in the question posted bellow. I will
    >> rephrase the question more clearly, perhaps this is the reason no one
    >> has bothered to try and assist me.
    >> I would like to know if there is a way I can group and move components
    >> in board editor based on a group selection made in the schematic editor.
    >> i.e.. I would like to select in the schematic all the components say
    >> aground my power supply and then have them selected in board enabling me
    >> to move them off to one corner of board. This way I can place them
    >> without searching through hundreds of component every time.
    >> I do apologise if this question has been asked before though I have
    >> searched the group and cannot find it if it has.
    have a look at http://www.cadsoft.de/downloads/file/apg.ulp
    I have not used this ulp myself though.
    Lorenz
    This is a public forum.   Most of the participants are fellow users and
    they are not compelled to answer your questions ..license or not.
    People here will usually provide an (sometimes very brief) answer to
    even the most basic questions so if you get absolutely no response its
    probably because a person who knows the answer has not read your post.
    Perhaps you were wanting to email Cadsoft support directly (see the
    email link provided on their support page under "Personal assistance").
    Jim
    On 5/1/2012 7:22 AM, Jannie wrote:
    I am entitled to
    assistance in this forum as I am a licence holder of Eagle 6 professional.
  • dukepro
    dukepro over 14 years ago in reply to e14 Contributor
    Jannie,
    I don't know of a way to do this directly.  You may be able to do this
    using a ULP... spin through the elements in a schematic and identify
    which ones are members of the group.  The ULP could emit script language
    to switch to the board and select those same components.
    The underlying problem, though, is that while the components selected in
    the board will be the same as those selected in the schematic, you will
    not be able to select any connecting traces.
    A step in this direction would be to design the ULP to be chained.  That
    is, do the above, then as the last command in the emitted script would
    be to run a different script that determines the extents of the
    components selected in the board, and groups them with a polygon.
    clearly this gets fairly complicated when one tries to determine the
    extent of each component, accounting for SMD pads, plated holes, etc.
    I am entitled to
    That's okay... I provide the content of my posts gratis.
    Enjoy,
        - Chuck
    Hello there
    searched the group and cannot find it if it has. I am entitled to
    Thanks for your prompt reply.
    Jannie
    just in groupings.
    Jannie du Preez
