EAGLE User Support (English) Silkscreen layout (Layer)
  • Views 519 views
Hey guys, I am planning to do silkscreen layer for my DIY PCB. So which layer should be visible and which layer should not be visible ?
Do we have option to choose where we want the entire layout to be in silkscreen layer ?
Thank you
    On Mon, 18 Jun 2012, Jim Littlefield wrote to us saying :
    I've usually seen people put tPlace, tNames, tDocument in the top
    >silkscreen.
    Usually not tDocument actually. For most libraries (although the
    supplied ones aren't consistent on it) the tPlace layer should contain
    the outline for the silk screen, while tDocu fills in the bits that have
    to be excluded for solder mask - i.e. the parts of the outline that
    cover the pads, such as pins.
    Of course if you're doing a top-side silk on a single-sided board then
    you may well want those extra bits.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    Thank you
    You can control which eagle layers get output into which gerber files in
    the CAM processor.   I've usually seen people put tPlace, tNames,
    tDocument in the top silkscreen.    Sometimes tValues is also included
    but this can get messy fast unless your layout is very sparse.
    Jim
