EAGLE User Support (English) Option for Persistent Show
  • Views 210 views
Hello everyone,
I know that this has been brought up before but I'll raise it to the top
again.
While routing, it would useful to be able to highlight a net (or group of
nets) permanently until the next show command to turn the highlight off.
Right now, the highlighting goes away on the next command which really
isn't very helpful.
I'll even suggest syntax:
show  ^ u1 u2;
This would persistently highlight those components.
show  ^ u3 u4;
This would highlight U3 and U4 with persistence while keeping U1 and U2
highlighted as well.
show  !;
This would clear the persistence and nothing would be highlighted
show  ! ^ u5 u6;
This would clear anything that was highlighted persistently and then
highlight U5 and U6 with persistence.  Of course, this should work with all
named objects (nets, traces, devices, ...)
This seems like it should be a relatively easy change and would be great
help during manual routing specifically.
Cheers,
James.
Specializing in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
    Am 28.06.2012 16:33, schrieb James Morrison:
    Hello everyone,
    again.
    isn't very helpful.
    show  ^ u1 u2;
    show  ^ u3 u4;
    show  !;
    show  ! ^ u5 u6;
    Cheers,
    James.
    Hi
    a suggest in the same direction:
    a "show" of the device in the shematic if the device is in brd selected
    to move.
    So we can see in the shematic witch C or R we move (it'S usefull for the
    C's on the Supply of OP.
    (Don't  know how to explain in english)
    (german version)
    Ein Vorschlag in die selbe Richtung.
    Es wäre hilfreich wenn beim Move eines Bauteils im Board es entsprechend
    im Schaltplan auf "show" gesetzt wird.
    So sieht man z.B. bei OP-versorgungen welchen der Stützkondesatoren im
    Board am Cursor hängt. ist auch für HF oder ähnliches hilfreich und
    reduziert das "show" "move" hin und her.
    Werner
