EAGLE User Support (English) Seems to be a mistake in  V-REG.lbr SOT89R
  • Views 482 views
It seems I found a mistake in standard library
SOT89R has 2 3 1 oder instead of usual 1 2 3
    Yes, I tried scripts from Farnell it is very good thing.
    I will pay more attention when use new components even from standard library. I just wanted to post this message in order to warn other people.
    Hello Dmitry Chikov !:
    Thats true. I had to check it. But I thaught if it is 3 pin IC, which
    is widely used - there were no chance to make a mistake. And it was
    vice versa - I ordered component according to LBR not find LBR
    according to IC. That was the problem. I would be really funny when
    Eagle make a cart directly from eagle app.
    This is possible using apriopriate ULP. But of course you MUST have good
    libraries.
    Did you try the new features connecting a bit Eagle to Farnell ?
    You use component from LBR Eagle -> order -> FAIL!!!! .
    I never used Eagle to generate order of material. And maybe 0,01% of
    material is from Farnell ...
    But I check all components which I am using in my projects. Some are
    from "original lib" but exactly checked with data sheet.
    BR
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    Thats true. I had to check it. But I thaught if it is 3 pin IC, which is widely used - there were no chance to make a mistake. And it was vice versa - I ordered component according to LBR not find LBR according to IC. That was the problem. It would be really funny when Eagle make a cart directly from eagle app.
    The most experienced users are talking : NOT to use any original lib
    before exactly check for some mistakes !!!. Best way is to create own
    libraries. Really a lot of libraries have very different errors incl.
    wrong raster for TQFP, wrong connection pins to pads etc.
    BR
    Grzegorz Zalot
    complex ltd.
    And not the only one I have couple of other mistakes.
