EAGLE User Support (English) Help with PCB Copper Pouring
  • Views 348 views
I am new to Eagle and having trouble with copper pouring. I use CAM
Processor to make Gerber file, but I want only routes to remain after
etching and rest of the copper to disappear!
Please help!
thanks in advance.
Haris
    On 7/13/2012 7:30 AM, Haris wrote:
    Please help!
    thanks in advance.
    Haris
         Not sure exactly what your question is?   If you don't create any
    polygons and you don't define any of the layers as power planes then you
    should only get traces, pads, and the annular rings around
    through-holes.  Obviously you should load up your gerber files in your
    favorite gerb viewer and make sure that the CAM processor has done what
    you want.....preferable before sending the board to fab.
    Jim
