EAGLE User Support (English) Newbie: EAGLE CAD Errors
  • Views 360 views
hello,
i received the land patter of a  LC4 package from a friend of mine...also
took the design rule limitation from my fabrication house. I applied the
DRC for this package and faced these three type of errors.. have a look at
attached picture.
can any one suggest where these problems comes from.. and how to resolve
this issue.
    I appriciate ur suggestions,
    yes ofcourse lowering the value removes the errors but i was wondering if
    ignoring the errors will affect the manufacturing process or not e.g
    dimension error or clearance error.
    also the board is produced from schematics, vias are placed manualy but
    named the same as 'gnd', polygon for tapering is also named the same as
    signal name for every signal and drawn with the same line width as the pad
    size...
    for better look i have attached both .brd and .sch file to the thread
    http://wikisend.com/download/134390/HMC144LC4.zip
    Usman Ali wrote:
    hello,
    mine...also took the design rule limitation from my fabrication
    house. I applied the DRC for this package and faced these three type
    of errors.. have a look at attached picture.
    resolve this issue.
    It's difficult to assist using just the provided image. Attatching the
    design .brd file would enable exact answers to be given by someone using v6
    as they would be abl eto deconstruct the method you have used
    So some educated guesses follow.
    All the errors on the lower edge of the board appear to arise from the
    package being placed to near to the edge of the board. I suspect the
    smd pads of the package are triggering the DRC error. The DRC setting to
    review is   DRC>Distance>Copper Dimension
    For a test, reduce the setting to a few mil and see if those errors do not
    occur on the next DRC check.
    Next you need to isolate the errors at the  three tapering traces know their
    types.
    I would endeavour to find the reasons for the errors around one tapering
    trace. The fix for those errors will rid you of the errors for the other two
    tapering traces. So, approve all the errors except those in the area of the
    tapering trace you choose to troubleshoot.
    I suspect you may not have ROUTEd the segments with reducing width but
    placed wires
    Purhaps  you did not generate this board from the schematic editor but built
    the board by itselft and and have not got the signal names matching.
    The clearance of your net classes may be conflicting with your DRC
    clearances so review those.
    Warren
