EAGLE User Support (English) update PART
  • Subscribers 190 subscribers
  • Views 408 views
update PART
js1234
js1234 over 14 years ago
Hi
I make difference on one part in library (package)!
Then make "update " library or "update all"  but on board is still old
package style!
Where is problem?
  • js1234
    js1234 over 14 years ago in reply to e14 Contributor
    I change PAD in package ..... wrong!!
    I edit in library device AND THEN package .........and after that in PCB
    update library!
    Works OK!
    Thanks to all!
    J.
    "Richard Hammerl" <support@cadsoft.de> wrote in message
    news:ju0tan$92p$4@cheetah.cadsoft.de...
    On 16.07.2012 13:16, Joe wrote:
    >> Hi
    >> package style!
    >> Where is problem?
    >> Thanks
    What do you change in the Package?
    Richard Hammerl
  • js1234
    js1234 over 14 years ago in reply to murray106
    I make difference in package only and therfore update not work!
    I edit in library device and then package .........and after that in PCB
    update library!
    Works OK!
    Thanks to all!
    J.
    "Paul Murray" <noreply-14371@element14.com> wrote in message
    news:163382606.3751342452433370.JavaMail.jive@flmspu-csapp-02.premierfarnell.com...
    Hi Joze,
    Simply save the library you were working in when making the change. Then
    in your board layout click library from drop down menu at top then select
    "update" then pick the library you modified! You should get a message
    saying "library been modified re-run DRC" (or something like that?)
  • murray106
    murray106 over 14 years ago
    Hi Joze,
    Simply save the library you were working in when making the change. Then in your board layout click library from drop down menu at top then select "update" then pick the library you modified! You should get a message saying "library been modified re-run DRC" (or something like that?)
    Hi
    package style!
    Where is problem?
    Richard Hammerl
