EAGLE User Support (English) Using internal layers effectively
  • Views 202 views
Dear All,
  I'm using a 4 layer board with SMDs mounted on one side only. The
auto-router is only getting about 85% of the connections, there are
about 550 total. However there are only about a dozen tracks on the
internal layers. I am using layers setup (12+316) for pcb-pool.
The problem seems to centre around a LQFP100 package that does not have
space to allow tracks between pins, however this only prevents a two
layer design. I have tried reducing the costs of internal layers and
reducing the costs of vias, but these do not end up having much effect.
Am I missing some strategy for using internal layers more effectively?
     Thanks in advance
                   Andrew
    First of all, a good parts placement is essential. Every hour you spend
    on the placement, you will save twice during layout.
    Second, autorouting will never provide really good results - especially
    in areas of higher density like around your LQFP100 device. Route this
    part manually, before eventually using the autorouter for the rest.
    (My designs are 100% manually routed.)
    Third, a common ML4 design strategy is to use the inner layers only for
    ground and supply voltages. All signal routing is done on the outer
    layers only. If you have placed your parts properly (see 1), you'll be
    able to route about 90-95% of your signals on the top layer (and the
    remaining 5-10% on the bottom layer). Take care that you have ground and
    supply layers, so you can exclude all supplies from ratsnest and don't
    let them confuse you during layout and optimization. Later, include
    ground and supplies in ratsnest again and add the needed connections as
    short stubs with vias into the planes.
    Tilmann
