EAGLE User Support (English) Problem installing Eagle 6.2.0 (Can't determine start folder)
  • Replies 8 replies
  • Subscribers 179 subscribers
  • Views 496 views
I have a problem installing Eagle 6.2.0 on a Windows 7 machine
I uninstalled my previous Eagle version en downloaded the most recent: 6.2.0
When installing is at 100% it failes with the message "Can't determine start folder" followed by the message "An error occured while installing Eagle. Please fix the problem and run Eagle setup again."
Anybody an idea how to actually fix this problem?
Thanks in advance.
    On 7/29/2012 8:09 AM, Bart Grootendorst wrote:
    Thanks in advance.
    Hi Bart,
    Is this a work machine? Do you have any restrictions on this computer
    which would inhibit you from being able to install EAGLE?
    Let me know what you find out.
    Best Regards,
    Jorge Garcia
    Former Member over 13 years ago in reply to Former Member
    Hi Jorge,
    The machine is a notebook on which I run Windows 7 professional with an account that has administrator rights. I also tried "Run as administrator" but without succes.
    Best regards,
    Bart
    On 7/30/2012 5:20 PM, Bart Grootendorst wrote:
    Hi Jorge,
    Best regards,
    Bart
    Hi Bart,
    Try downloading the installer again and running the new one, sometimes
    the installer doesn't download properly.
    If that fails please let me know and I'll see what else we can try.
    Best Regards,
    Jorge Garcia
  • techsupport
    techsupport over 13 years ago
    Not sure if this helps, but after downloading the Setup Executable, change the file properties to be XP compatible and select the option 'RUN as ADMINISTRATOR'.  There are times that the multiple layers of protection of W7 don't allow certain application to install properly.
    I hope this helps,
    Ed
    Former Member over 12 years ago in reply to Former Member
    Is there a solution to this problem?  I'm experiencing the same "Can't determine start folder" error message as the original poster when trying to install EAGLE 6.5.0 on a Windows 7 Pro machine using an administrator account.  I've tried the solutions suggested in this thread with no success.
    autodeskguest over 12 years ago in reply to Former Member
    Is there a solution for this problem?  I'm experiencing the same "Can't
    success.
    http://www.element14.com/community/message/89556#89556
    success.
    http://www.element14.com/community/message/89557#89557
  • techsupport
    techsupport over 12 years ago in reply to Former Member
    Is it possible you have previous installation of EAGLE? if you do, then find and delete the eaglerc.usr file, should be located in your Documents folder.  This is the file used by EAGLE for startup.
    I hope this helps.
    Ed
