I'm having problems making changes to a schematic I created a couple of
weeks ago. Basically I can't get any new nets to actually connect to any of
the pins I drop them on. I can place the ends of the net without problems,
but if I then try to pick up and move either the component or the net then
the two become separated (demonstrating that they weren't connected
properly in the first place). I've had this problem before, and it can
normally be cured by matching the size of the schematic grid to the
component grid. However, this isn't working this time.
I've also tried setting the grid size to 'finest' and zooming right onto
the components before attempting the connection, but the results are the
same. There's nothing special about any of the components I'm using either,
I've already got several copies of them successfully connected elsewhere on
the same schematic.
I'm using version 5.11 for windows running on windows XP professional.
Any help appreciated!
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
