EAGLE User Support (English) Integrate with Circuit Simulator
  • Subscribers 189 subscribers
  • Views 867 views
It would be great if Cadsoft offered an integrated software simulator to go along with Eagle. I have the B2 Spice software, but it never really integrated well (or at all) with Eagle. That is the one thing that I really miss.
    Compatability with established simulation programsis a great idea. It doesn't effect the functionality of Eagle at all, only allows the expansion of it's existing capabilities by adding an aditional capability. I have used Eagle for many years, but still learn new things when I venture out of my comfort zone of usual procedures. I would not like to go to a new system, partly because of expense, but adding a capability for interfacing with a simulation tool would greatly reduce my production cost by reducing the number of prototypes I have to produce.
    Thomas
  • CSWalt
    CSWalt over 14 years ago in reply to e14 Contributor
    Hi Andrew,
    On 08/16/2012 12:59 AM, Andrew Sterian wrote:
    On 8/15/12 6:33 PM, Jorge Garcia wrote:
    >> On 8/15/2012 12:57 PM, Thomas Holley wrote:
    >>> Is there any plan to upgrade Eagle with simulation?
    >> Hi Thomas,
    >> There are plans to do this. Keep your eyes open you should see something
    >> by the end of this year.
    >> hth,
    >> Jorge Garcia
    >> Cadsoft Support
    Ugh, sounds like you guys are "chasing rainbows". Real simulation takes thought and careful modelling, Eagle is not
    meant for this. How is the user going to indicate that the 2-pin connector that represents a voltage input to the PCB
    should be modelled by a voltage source with 2.3 ohm series resistance and 100us risetime?
    There are about 1 bazillion REALLY GOOD ideas on this newsgroup for improving Eagle's SCHEMATIC AND LAYOUT abilities
    that have been around forever (well...at least since v3 when I started) that just never get implemented. If Eagle chases
    the low-cost "pretty face" CAD tools by implementing "simulation lite" it is entering a race to the bottom; instead of
    being the best tool in its class it will be just another little fish in a big sea of mediocre tools intended for
    hobbyists. It's already headed that way with the Newark integration {smiley eek jivemacro verylame}.
    That's some misunderstanding. We are not developing simulation capabilities ourselves, we're working on import/export
    between EAGLE and a simulation system based on SPICE. We would have that already if there weren't much differences
    (partly incompatibilities) in the data models.
    I agree, it would be a bad idea to leave our market area PCB design.
    And yes, we have plenty of good suggestions from our customers that we partly pick up (depending on reasonability
    and feasibility) to become better and better image
    The Newark integration is not part of our software and not from us.
    Hope this makes things clearer.
    Walter Spermann
    It's sad. Just IMHO.
    Andrew.
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    Hi Thomas,
    hth,
    Jorge Garcia
    Cadsoft Support
    takes thought and careful modelling, Eagle is not meant for this. How is
    voltage input to the PCB should be modelled by a voltage source with 2.3
    improving Eagle's SCHEMATIC AND LAYOUT abilities that have been around
    implemented. If Eagle chases the low-cost "pretty face" CAD tools by
    instead of being the best tool in its class it will be just another
    little fish in a big sea of mediocre tools intended for hobbyists. It's
    Andrew.
    Hi Thomas,
    hth,
    Jorge Garcia
    Cadsoft Support
