EAGLE User Support (English) Via diameter size control
  • Views 421 views
rtzaudio
rtzaudio over 14 years ago
The global sizing of via diameters in the DRC just doesn't cut it for
hi-tech BGA stuff. We need a way to override the DRC for both under and
over the DRC limit vias. Once you move to high density fine pitch BGA's,
via size control becomes a real problem.
I understand how "auto" via size parameter works, but for things like
"via in pad" and "micro vias" and stacked micro vias, the current
implementation for controlling via diameters is just not suitable.
While the global DRC auto size and parameters works for the majority of
vias on a board, often I need to specify smaller annular rings in the
BGA field than I would from all other vias on the board.
Sure, I could set the DRC parameter to smallest ring I need in the BGA
area, but then I'd have to manually specify the diameter of every other
via outside my BGA area as larger - what a pain!
The via size parameter needs to fully respect the value given if the
diameter specified is not auto and smaller than the DRC limit. Maybe the
diameter could be specified negative or something, but we need a way to
override this "auto" minimum size feature.
This has been killing me for a long time and causes great pains routing
these high density BGA's. Please give use a way to control the via
diameters completely at the via level!
Bob
    and over the DRC limit vias. Once you move to high density fine pitch
    BGA's, via size control becomes a real problem.
    of vias on a board, often I need to specify smaller annular rings in
    the BGA field than I would from all other vias on the board.
    other via outside my BGA area as larger - what a pain!
    the diameter could be specified negative or something, but we need a
    way to override this "auto" minimum size feature.
    routing these high density BGA's. Please give use a way to control
    the via diameters completely at the via level!
    Bob
    I agree.
    There are other inate Eagle features that are now impacted by  the scale of
    the modern componentry. They have been highlighted over the months.
    A similar issue to Bob's request, and needs to be addressed at the same
    time,  is  the ability to specify a hole that the copper does not stay clear
    of.
    A raw 'Drill' that can be part of a package or placed on the Board.
    Said another way, a Hole that is not reflected in the Dimension layer but is
    in the Drill layer.
    Warren
    news.cadsoft.de
