    • Avnet Boards Community
EAGLE User Support (English) View rotation and mirror
  • Replies 22 replies
  • Subscribers 177 subscribers
  • Views 2251 views
There are times when it would be very handy to be able to rotate the
view of a PCB layout or schematic. I don't mean by changing the layout
or schematic itself, but rotate how the layout or schematic is VIEWED.
It'd also be handy to be able to flip a PCB over so you're viewing it
from the bottom, rather than the top.
This is nothing more than coordinate translation when drawing the screen
and interpreting click locations. It wouldn't change anything stored in
the schematic or board file, so the effects in the code should be
relatively localized.
    Former Member over 13 years ago in reply to Former Member
    Am 27.08.2012 12:50, schrieb Richard Herman:
    Well, at least is it not on the "EAGLE Feature Survey" that Jorge Garcia
    posted on Google doc's. So it's probably not high on Cadsoft's "what to
    implement next" list.
    Wasn't actually aware of such a survey, and I'm following the newsgroup
    on a regular base. Anyone got a link? Then I will add the mirror feature image
    Markus
    Op Mon, 27 Aug 2012 21:41:40 +0200 schreef Markus Rudolf
    <user@domain.invalid>:
    Markus
    It was announced in (at least) the eagle.userchat.eng group a couple of
    days ago.
    Here's the link:
    http://docs.google.com/spreadsheet/viewform?formkey=dEF4MWdPVXgxNjdHMk9aWE5wOTNyQmc6MQ
    Although someone in that thread claimed the link didn't work for him, it
    works fine for me.
    Richard
  • CSWalt
    CSWalt over 13 years ago in reply to Former Member
    On 08/27/12 21:37, Markus Rudolf wrote:
    Am 27.08.2012 14:30, schrieb Walter Spermann:
    >>   - Just if you are not aware: There is the print preview,
    >>     that allows to see the drawing rotated or mirrored. If you just
    >> want to see it without
    >>     editing this should be quite helpful.
    Is a pain. I just want a quick view from the bottom to see if the
    (otherwise mirrored) silkscreen looks nicely and is aligned proper.
    I tend to have silkscreen always on both sides and label every
    conenctor's pad with the signal name and such for making debugging a
    board easier.
    First thing that always comes up in this discussions is "theres an ULP
    for that" (like for any basic function a CAD system should have as a
    builtin command caugh), but that modifies the board's objects /
    datastructures and this cannot be meant like always undo/redo stuff.
    Plus its slow and doesnt work proper with multilayer boards as i found out.
    >>   - What's the advantage of editing the drawing in mirrored or rotated
    >> state ?
    >>     It may be good to get a realistic impresion of how the board looks
    >> from behind or side.
    >>     On the other hand you'll have trouble reading the texts.
    >> We have doubts if this makes so much sense. Pls. let us know in which
    >> cases it makes sense.
    As stated above, I use would use it for fine tuning silkscreen and such.
    Right now I am really printing out mirrored 1:1 copies on our Laserjet
    and do the manual iteration. That sucks and wastes resources and my time.
    OK, we put this on our todo list. I can't make commitments when it will be implemented.
    There are many more wishes from customers (like import/export, many other GUI oriented and
    informatioal features), and our development staff is very limited.
    Plus I really don't see any difficulties implementing that in an
    hopefully object-oriented programmed CAD Software on a low level for
    drawing the primitives like lines and such. It's basically just a factor
    of -1 on the proper positions in the code.
    Well, it's not as simple as that. At least there is a GUI extension necessary for that,
    the EAGLE command syntax needs to be extended and some other stuff.
    I would not even care if the mirrored view is just a view which I cannot
    edit anything, but just with a hotkey flip the view back and forth and
    Zoom and Pan.
    Of course if this can be done without to much trouble, count me in....
    Markus
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
  • CSWalt
    >> newsgroup on a regular base. Anyone got a link? Then I will add the
    >> Markus
    days ago.
    Here's the link:
    works fine for me.
    Richard
    just a remark:
    Not all topics on this list have high priority or are already on our todo list.
    You may also add new suggestions in the comment section of the survey.
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
  • CSWalt
    On 08/27/12 12:50, Richard Herman wrote:
    Op Mon, 27 Aug 2012 11:28:19 +0200 schreef Markus Rudolf
    >>> Me too. Possibly easy to implement - wondering why it was ignored for so
    >>> long....
    >>> Stefan
    >> Because the more people want it, the more it is ignored. That's at
    >> least my impression image
    >> Markus
    BTW, what do others make of that survey? I'm glad that at least Eagle
    for smartphones is on the list! Doing serious layout work on my phone
    has been high on my personal wish list! duhh...
    Richard
    the point is actually "EAGLE for Tablet or Smartphones" and we primariliy think of tablets.
    Is smartphones really an option ? Can you imagine doing PCB-design on such a small display,
    only with touchscreen ?
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
  • dukepro
    dukepro over 13 years ago in reply to CSWalt
    On 08/27/2012 08:30 AM, Walter Spermann wrote:
    Hi Richard and others,
    A few points /questions:
    - What's the advantage of editing the drawing in mirrored or rotated state ?
       It may be good to get a realistic impresion of how the board looks from behind or side.
    I believe the referenced rotation is about the Z-axis, not the X or Y
    axes.  After all, it doesn't make much sense to view the board edge on.
    I agree that it'd be nice to be able to rotate the board, or to flip it
    over.  Most of the solid object modeling packages I have encountered use
    a set of XYZ arrows in the bottom left corner of the screen as a
    reference to how the model is being displayed.  Something similar could
    be included with this function in Eagle, limiting of course, to just the
    X (red) and Y (blue) directions.  In the normal top-down view, these
    would follow the right-hand rule; in the bottom-up view, they'd be
    left-hand.
        - Chuck
    Former Member over 13 years ago in reply to CSWalt
    Am 28.08.2012 11:41, schrieb Walter Spermann:
    I'm 100% sure that NOBODY wants to use EAGLE on a system without mouse
    or other PRECISE pointing device. Perhaps for LOOKING at files, but
    quite definitely NOT for DOING things.
    Andreas Weidner
    First I thought you're absolutely right - but then, looking at people
    who extensively waste time in web based forums or social networks,
    access their mail by web mailer, etc. pp., and looking at some of the
    questions coming up here lately (particularly from the e14 forums), I
    must confess that I'm not really 100% sure about this any more... :-\
    Tilmann
    Op Tue, 28 Aug 2012 16:54:59 +0200 schreef Andreas Weidner
    <andreas.weidner@aei.mpg.de>:
    Andreas Weidner
    Exactly, even looking at files on a standard 10" tablet screen, doesn't
    really appeal to me.
    I would move this to the bottom of the "to-do" list. But to each his own.
    Richard
    On 8/28/2012 5:41 AM, Walter Spermann wrote:
    >> Richard
    Walter Spermann
    Hi Guys,
    As the maker of the survey, I think I should chime in on this. The first
    survey I did received too many other(they didn't select one of the
    provided responses) responses so I tried to cover more features. The
    EAGLE for smartphones and tablets is there because believe it or not I
    do get support calls with people asking when EAGLE will be available for
    Android.
    It doesn't make any sense to me, but I put it on there. If it's truly as
    useless as we all think it is then that will reflect in a low number of
    votes for that feature.
    On the flip side(pun intended)I can't hope to cover every possible
    feature request from thousands of users and that's why the comment
    section is there. I go through all of the comments so anything I left
    out of the main selection that is important will pop up there.
    hth,
    Jorge Garcia
