EAGLE User Support (English) Circle command explained?
  • Subscribers 189 subscribers
  • Views 884 views
The CIRCLE command (as usable in an ULP) has the structure
CIRCLE (X Y) (A B)
X and Y are clear. The rest is not clear to me from the help file.
Either A or B seem to function as the Radius, so (0 10) or (10 0) look
to be the same. (5 10) gives some value in between. There seems to be no
influence on the Width of the circle drawn.
Why do we have both parameters A and B?
Regards, Robert
    e14 Contributor over 13 years ago in reply to dukepro
    On 28/08/2012 15:34, Chuck Huber wrote:
    On 08/28/2012 09:19 AM, Tilmann Reh wrote:
    >> The two coordinates for the circle command are the center and any
    >> position on its diameter.
    ... on its circumference.
    >>> CIRCLE (X Y) (A B)
    CIRCLE (0 10) (10 0)
    will generate a circle centered on (0 10) with a radius of 14.14.
    Thanks for the explanation.
    Robert
  • dukepro
    dukepro over 13 years ago in reply to e14 Contributor
    >> CIRCLE (X Y) (A B)
    ...probably you mean SCRIPT...
    CIRCLE (X Y) (A B)
    That aren't parameters resp. values, it's a /coordinate/ on the circle.
    Tilmann
