EAGLE User Support (English) export board outline?
  • Subscribers 189 subscribers
  • Views 1354 views
I am making several boards with common connector layout and mounting holes.
Have one board laid out so far and want to take this to use as a template
for others. What would be the best way to do this?
tia - Oppie
    e14 Contributor over 13 years ago in reply to Morosh
    "Maurice SAAB" <morisaab@yahoo.fr> wrote in message
    news:k7bmgn$jqu$1@cheetah.cadsoft.de...
    Using "hierarchical.zip" (in ulp download section), you can convert your
    board ans schematic to a device in library. So you preserve the layout you
    want.
    Thank You Maurice, Warren and Marco.
      Oppie
    Marco Trapanese wrote:
    Il 06/11/2012 19:15, Oppie ha scritto:
    >> Tried making a library footprint by pasting in a copy of the board.
    >> Would not accept the components on the board like the connectors I
    >> wanted to use. I suppose I could just make a dimension markup in the
    >> measures layer to give outline and center marks of connectors and
    >> holes.
    You can't copy and paste from board. But you can within libraries. So
    draw the outline and the reference holes in a new package. Then place
    the pads for your connector (from scratch or pasting the package of an
    existing one). Create a symbol with the same connector including other
    pins if needed. Eventually complete the job creating the device.
    Marco
    You can copy the board outline, holes and text etc. and  paste it into a new
    package.
    Leaving only the pads for the connectors to be added..
    Follow along:
    In the board editor, clear the group with the following line in the command
    line.
    GROUP;
    Next select the GROUP icon.  Add the board dimension lines and the holes to
    the new group one at a time by holding the CTL key as you click the objects.
    When ready, select enter COPY(>0 0); to copy the group .
    By moving the cursor you can confirm if you have selected all the lines and
    holes.
    You can press Esc to get the selection off the cursor.
    Open your library and open a new package.
    Enter into the command line   PASTE(>0 0);
    You may need to group the objects again and move them to get the origin to a
    different place.
    Then add to the package the pads and other objects you need.
    HTH
    Warren
    news.cadsoft.de
    measures layer to give outline and center marks of connectors and holes.
    Marco
  • Morosh
    Morosh over 13 years ago
    holes. Have one board laid out so far and want to take this to use as a
    template for others. What would be the best way to do this?
    tia - Oppie
    you want.
    HTH
    "Marco Trapanese" <marcotrapaneseNOSPAM@gmail.com> wrote in message
    news:k7bjlo$7i3$1@cheetah.cadsoft.de...
    You may create a new part in your library with the connector and the
    mounting holes.
    Tried making a library footprint by pasting in a copy of the board. Would
    not accept the components on the board like the connectors I wanted to use.
    I suppose I could just make a dimension markup in the measures layer to give
    mounting holes.
    Marco
