EAGLE User Support (English) Manually route 4 layer board?
  • Views 298 views
Perhaps I should look at upgrading to autorouter but when I was getting my license I didn't include it, as I only ever do small boards. I'm still only doing small boards but with the microcontrollers with more and more pins and in more compact packages I decided that I'd start trying out a four layer board. I decided that I'd put power and ground layers into my board and whilst that works actually routing is a probelm as Eagle tells me everywhere that it can't place a via where I've placed it. Seems manually routing is out of the question.
If anybody knows of a useful resource on this I'd be glad of the help. Both the manual and the tutorial didn't really help me out of the problems.
    Thanks Jorge I must have been trying to place a via in a restricted area as that is working. Thanks for you help
    Hi John,
    You never have to preplace vias when your manually routing using the
    ROUTE command. The procedure for placing a via while routing manually is
    as follows:
    1. Left click on the pad you wish to start from.
    2. Continue routing until you reach the point where you wish to drop a
    via. Left click to stop the segment.
    3. Click your Mouse Scroll wheel as if it were a button. Select what
    layer you wish to transition to.
    4. Continue routing, the next time you left click to stop a segment
    EAGLE will drop the via at the transition point for you.
    hth,
    Jorge Garcia
