EAGLE User Support (English) how to remove duplicate libraries
  • Subscribers 189 subscribers
  • Views 822 views
scott216
scott216 over 13 years ago
When I go to add a component, I noticed there are duplicates of all the
SparkFun components.  I looked in my library directory and I only see one
set of SparkFun files.  How can I track down the duplicate files and
remove?
    e14 Contributor over 13 years ago in reply to scott216
    On 05.01.2013 13:03, Scott Goldthwaite wrote:
    I figured it out.  Eagle was looking for library files in both my Eagle 6.3
    and 6.2 directories.  I'm not sure why it was still searching 6.2.  I
    removed the 6.2 lib directory and everything is fine now.
    You coulad also set the correct Library path in the EAGLE Control Panel
    and type the following two lines into the command line in the schematic
    or board editor window:
       USE -*;
       USE *;
    First line "unloads" all libraries, second loads all libraries that are
    in the libraries path.
    Richard Hammerl
  • scott216
    Am 04.01.2013 14:06, schrieb Scott Goldthwaite:
    remove?
    Check control panel options/directories if there is a path to a
    different directory.
    Joern Paschedag
    In the schmatic page, you can click the replace button to replace the component.
